MK63 Brakes
From Datsun 1200 Club
Category: Brake Modifications
Nissan competition MK63 racing brakes fit Z-car struts and A10/B310 large (13" wheel) struts. See Strut Swaps.
These were the FIA brake calipers, offered in the Nissan 'Sports Option' parts lists in Japan, and through Datsun Competition in the USA. They were fitted to most of the works 240Z and 260Z rally cars, most of the works circuit racing 432R and 240ZR race cars, as well as many of Skyline, Sunny and Violet race cars.
  • Approximately 50% more pad area than stock 240Z brakes
  • Require removal of the backing plate. Complete bolt-on.
  • Feral used 261 mm diameter or even 253 mm rotors.
  • early S110 rear discs and calipers were small and very light and fit under 13's.
The discs were same as R31 skyline...discs and calipers came on an E-PS110 Z20E powered with FS5w71B & HB 38 rear axle. It had an SX badge on the rear hatch.
Nismo MK63 Sumitomo 4 pot calipers
  • 89.9 bolt spacing
  • Has four 41.3 mm pistons
  • Caliper repair kit 41120-68225 fixes all seals for one caliper
  • Replacement piston 41124-68200
M59 formula brake pads
Benny
Benny managed to squeeze R32/S13 280mm front rotors and Sumitomo 4 spots on Stanza struts -- custom caliper bracket mounts to std stanza caliper pick up points. "I can still fit my 14 inch superlights over the them."
mid corner - turn 1 run 14s over R32 rotors and calipers. R32's are on stanza struts and calipers are the "sumitomo 4-pots". used C22 vanette hubs [have different offset, but use the same bearings] with the R32 rotors [ 280mm dia] had to make up braket for caliper as the center to centre spacing on the strut is 90mm and the caliper is 100mm. position of caliper to rotor relationship is spot on.....
Calipers
full
full
full
full
full
full
MK63 Solid Rotor
For stock 240Z solid rotor, and stock 240Z strut. Available from Courtesy Nissan $700 USD
* 41000-E7201 FIA Caliper RH
* 41010-E7201 FIA Caliper LH
* 99996-E7050 Install kit (hoses, fittings, bolts, washers)
* 41060-RS610 M59S Compound Brake Pads
* 41060-R1120 M2800 compound Brake Pads
For B310, you may need to change the hub.
MK63 Ventilated Rotor
For 20mm thick ventilated rotors
* Calipers (41001-A1281 RH, 41011-A1281 LH)
* Rotor 40206-N3120 vented
* Installation Kit 99996-E7051, which includes:
** Caliper bolts (4 needed) 41250-RR610, M12X1.25X31.5
** Hose Gasket 46237-A4600 (6 needed) $0.38 ea. from B310
** Hose bolt 41128-F1800 (2), M10x1.0x26.5
** Brake hoses 41205-F1800 RH, 41215-F1800 LH
**: Hoses from Nissan President?
* Rotor Fixing Bolt (8) 01111-00312, $2.22 ea. from B310
* 102 mm brake pads, 15mm total thick including backing plate
Needed for 240z up to 7/73
* 40202-N3426
Needed for B310 strut
* Hub 40202-A0127 from Datsun 810 (2 needed) $168.65 ea.
Pads
* 41060-A1281 M59S compound
* 41060-A1282 DS11 compound
* 41060-F0225 M33S compound
* 41060-E4622 M2800 compound
photo  photo
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=MK63_Brakes"
This page has been accessed 12,463 times. This page was last modified 10:47, 5 May 2016. Content is available under Datsun 1200 Club.
