Residual Valve
From Datsun 1200 Club
Categories: Brake System | Brake Modifications
The Residual Check Valve preloads the drum brakes with about 10 psi pressure. If you have front disk/rear drum, only the portion of the M/C for the drums has a residual valve. Disk brakes must not use a Residual Valve, but only need a weak pressure which naturally results from the M/C being mounted high on the firewall. However, some all-disc Master Cylinder use a low-pressue check valve, so check the application.
23167.jpgAlbum 23167
Sometimes called RLPV (residual line pressure valve), or RPCV (residual pressure check valve).
  • Datsun 1200 all-drum and disk-drum dual master cylinders are identical, except the latter has one residual valve fitted.
  • When converting from all-drums to disk-drums, use the all-drum cylinder, but remove the Residual Valve from the "F" portion. If the RV is left in place, the brakes will still work OK, but will wear faster than normal
  • Locking front brakes is not likely to be caused by a RV. More likely the M/C pushrod is not adjusted correctly, the Caliper pistons are sticking or some other problem. If using custom brake setups, the wrong combinations of parts may be fitted (e.g. proportions are off).
  • If relocating a disk-brake master cylinder below the floor a low-pressure check valve should be fitted.
Older all-drum models use a single-cylinder master cylinder. These are unsuitable for use with a disk/drum combo. Plus not as safe, so you should convert to a tandem master cylinder, for which you need the cylinder and brake lines. These usually come with a differential pressure valve to light the dash lamp indicating a brake failure.
Late model Sunny Trucks use a disk-drum combo with a tandem master cylinder with SINGLE brake fluid reservoir. Although using a single reservoir, the cylinder is a dual unit, and has separate front and rear line outputs.
Proportioning
Brake proportioning is not a function of the Residual Valve.
If you fit stock 1200 type disc brakes, then modify or change the master cylinder (remove the RV from the front circuit) AND replace the rear wheel cylinders with 11/16" units.
See Brake Proportioning
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Residual_Valve"
This page has been accessed 12,257 times. This page was last modified 21:06, 17 September 2017. Content is available under Datsun 1200 Club.
