Canopy
From Datsun 1200 Club
Categories: Body | Fibreglass
Datsun 1200 Trucks look good with a canopy.
A canopy (camper shell, sometimes called truck topper, truck cap, bed cap, box cap, or simply shell) is a small tray/bed housing used as an accessory for a pickup truck or coupe utility. The Datsun 1200 Truck is a coupe utility. This covers the cargo from the weather and in many cases looks stylish. A soft-top version is called a Tarpaulin.
2784.jpgAlbum 2784 2785.jpgAlbum 2785 2836.jpgAlbum 2836 12898.jpgAlbum 12898 12899.jpgAlbum 12899
13507.jpgTarpaulin
Bakkie
In South Africa, fitting a canopy to the B140 is very popular.
12946.jpgAlbum 12946 10789.jpgAlbum 10789 22155.jpgAlbum 22155
Beekman
174_68fdb053399b4.jpg#Half Door 174_68fd912fb497e.jpg#Full Door
SUPER CANOPY BY
BEEKMAN FIBREGLASS (CAPE) (Pty) Ltd.
BOX 76 SANLAMHOF 7532 CAPE PROVINCE
Super Canopy Half Door
174_68fdb053399b4.jpgPost 499085 174_61b3cf198c5b7.jpgPost 496307 174_61b3cf209e9ee.jpgPost 496307 174_61b3cf297037a.jpgPost 496307
5-window version
174_68fdaf1eb4952.jpgPost 499085 174_68fdaf19cd7d2.jpgPost 499085 174_68fdaf326827d.jpgPost 499085
Super Canopy Full Door
174_68fd9082b7260.jpgPost 499084 174_68fd912fb497e.jpgPost 499084
Bucco
Sadly, it seem Bucco is no longer selling B140 canopies.
Nissan 1400 Full Door Canopy
8770.jpgAlbum 8770
Nissan 1400 Half Door Canopy
31056.jpgAlbum 31056
  • Canopy bolted to vehicle as standard fitting for higher safety
2-Bar Roof Rack as a standard feature - feet are made from non-corrosive high tensile plastic and cross-bars are epoxy coated oval steel tubes (100Kgs Max. Load)
  • Fibreglass double skinned lockable rear lif-up door with large toughened automotive safety glass for greater visibility, heavy duty double gas struts opening mechanism and two-way locking mechanism which locks door to reinforced side plates for greater stability
  • Sliding lockable windows and additional fixed windows are rubber mounted (kick-out) on each side with maximum length toughened automotive safety glass
  • Canopy is designed to seal to the rear of the vehicle's cab and easy access is obtained through the vehicle's rear cab sliding window.
Optional extras:
  • Colour coding to match the vehicle colour
  • Window tinting to reduce internal heat and for greater safety
  • Non-slip Polyurethane Lining to vehicle's bin
  • 3rd Brake Light fitted to the rear of the canopy
  • Fitted PVC Air Vents
  • Excalibur Running Boards
  • Internal Switchable Strip Light
  • Heavy Duty Roof Rack (250Kg Max. Load)
  • Clip-on adaption for easily removable canopy (for safety reasons, not recommended)
  • Woven Rubber Bin Mat
  • Tow Bar and/or Bull Bar
  • Internal or external burglar guards for all canopy windows.
Canopy King
http://www.canopyking.com
Classic Half Door
31063.jpgAlbum 31063
Classic Full Door
31064.jpgAlbum 31064 31065.jpgAlbum 31065
SA Canopy
http://sacanopy.co.za
31057.jpgAlbum 31057
SA CANOPY 2010 LIST
NSA001 NISSAN 1400 HD F/G/D
NSA001AV NISSAN 1400 HD F/G/D + AIRVENT
NSA065 NISSAN 1400 HD F/G/D - B/SIDES
NSA085 NISSAN 1400 HD F/G/D - C/BLANK
NSA004 NISSAN 1400 FULL DOOR
NSA055 NISSAN 1400 FULL DOOR - B/SIDES
NSA103 NISSAN 1400 FULL DOOR - C/BLANK
NSA128 NISSAN 1400 HD F/G/D SPORT
NSA131 NISSAN 1400 SPACESAVER
SA Canopy Carryboy SA Series
31058.jpgAlbum 31058 31059.jpgAlbum 31059
31060.jpgAlbum 31060 31061.jpgAlbum 31061 31062.jpgAlbum 31062
Skytop
Skytop - one of the strongest canopies available!
Nissan1400A.jpg Nissan1400B.jpg Nissan1400C.jpg Nissan1400D.jpg Nissan1400E.jpg
On 18th July, 2000, at our Edenvale factory, we decided to 'put our canopy where our mouth is' and perform the ultimate strength test on the Skytop. Four canopy shells were randomly selected off the production line, and our Nissan 1400 was lowered by crane directly onto their roofs! Notice that no bending, buckling or distortion occurred when the full weight of the vehicle was brought to bear on the roof of each canopy! After the test these four shells went back onto the assembly line without so much as a hairline crack, or being any worse-off for their punishing ordeal.
Stingray Marine
Stingray Marine Canopiesᴬᴿᶜᴴᴵⱽᴱ Stingray Marine Canopies
31066.jpgAlbum 31066 31067.jpgAlbum 31067
Bakkie Canopy Photo Index
More photos at Bakkie Gallery
05c5_20.jpg 058a_20.jpg 061c_20.jpg 065e_20.jpg 85c7_20.jpg 15913.jpgAlbum 15913 0d18_20.jpg 4b85_20.jpg 4cf1_20.jpg 6d43_20.jpg 9f69_20.jpg 91c3_20-X.jpg 493e_20.jpg 01011eg_20.jpg 1530amb_20.jpg 2469kjm_20.jpg 02582nf_20.jpg 4822dnm_20.jpg 5585c97_20.jpg 5789_20.jpg 6670cha_20.jpg 7331mn3_20.jpg 7400ahm_20.jpg 8179hgl_20.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Canopy"
This page has been accessed 23,453 times. This page was last modified 07:36, 26 October 2025. Content is available under Datsun 1200 Club.
