PB110 used a heavier duty suspension with larger brakes. It is basically to the same specification as the HB210 (A14 B210) but with 12" wheels.
- 40160-A8625 BALL JOINT ASS'Y-front suspension $118.67 USD
- superceeded 40160-A8600
- 40052-H2501 ARM-knuckle (R.H.) $52.70 USD
- 40053-H2501 ARM-knuckle (L.H.) $52.70 USD
ALL
- 40234-21000 CAP-hub, front wheel $3.75 USD
- 40234-28500 CAP-hub, front wheel (from '71-4) $2.18 USD
- 40290-28500 RING-"O" (from '71-4) $0.53 USD
DRUM Brake for GX
- 40202-21000 HUB ASS'Y-road wheel [front hub] DX
- 40242-21000 CATCHER-grease, front DX
- 43206-4M700 DRUM-brake DX $148.58 USD
- superceeded 40206-21001
DISC Brake for GL & GX
- 40202-22051 HUB ASS'Y-road wheel [front hub] GL,GX $159.40 USD
- superseded 40202-22000
- 40206-A1155 ROTOR-disc brake GL,GX $137.55 USD
- superseded 40206-A1100
- 41000-R0100 CALIPER ASS'Y-front brake (R.H.)
- 41010-R0100 CALIPER ASS'Y-front brake (L.H.)
- 41060-A6900 PAD
- 41151-22000 PLATE-baffle (R.H.)
- 41161-22000 PLATE-baffle (L.H.)
- 41121-U6700 Piston-a $44.50 USD
- superseded 41121-A6900 PISTON-A
- 41122-U6700 Piston $43.70 USD
- superseded 41122-A6900 PISTON-B
DRUM BRAKE MASTER CYLINDER ADAPTER PLATE
The PB110 firewall is drilled for a 4-bolt vacuum booster. This plate is used to bolt on the simpler 2-bolt non-vacuum brake master.
- 47230-H2500 PLATE ASS'Y-master cylinder DX
- 89-11108-1 NUT (6) DX
- 89-15138-1 WASHER-lock (6) DX
BRAKE BOOSTER
- 47210-H2601 MASTER VAC ASS'Y GL,DX (op.) DX
- 47211-U7400 Spacer Mstr Vac $22.88 USD
- Superseded 47211-26701 SPACER-master vac
- 89-11108-1 NUT
PB110 Steering Gearbox
The gearbox looks similar to the regular 1200, and likely even bolts in its place. Probably the ratio is different. The GL and GX models were fitted with collapsible column and separate gearbox.
- 48011-21000 HOUSING COMP.-steering ALL
- 48103-21000 SHAFT-sector, steering ALL
- 48010-H2551 GEAR ASS'Y-steering DX [rigid]
- 48150-H2500 WORM ASS'Y-steering DX
- 48103-21000 SHAFT-sector, steering DX
- 89-11250-1 NUT
- 89-15150-1 WASHER-lock
- 48010-26150 GEAR ASS'Y-steering GL,GX [collapsible with U-joint]
- 48150-26100 WORM ASS'Y-steering GL,GX
- 48502-A0600 ARM-steering gear ALL
