Parts from Datsun Bluebird 510 that fit Sunny.
B10
23164-H0100 BOLT-SETTING 23153-H0100 ASSY-NUT,PULLEY 31918-H0100 ASSY-INHIBITOR SWITCH 31931-H0101 ASSY-VACUUM,DIAPHRAGM 23127-H0300 ASSY-COVER,REAR 23230-H0300 ASSY-DIODE 23133-H0300 ASSY-HOLDER,BRUSH 23135-H0300 ASSY-BRUSH(F) 23118-H0300 ASSY-COVER,FRONT 23236-H0300 COVER-DIODE 23156-H0300 ASSY-BOLT,TERMINAL 23247-H0300 SLEEVE 23131-H0300 BOLT-THROUGH 23133-H0301 ASSY-HOLDER,BRUSH 23135-H0301 ASSY-BRUSH(E) 23131-H0301 BOLT-THROUGH
B110
16331-H1000 ASSY-COMPENSATOR 16331-H1000 ASSY-COMPENSATOR,IDLE 17312-H1000 DRAIN PLUG PACKING 17310-H1000 DRAIN PLUG 17312-H1000 DRAIN PLUG GASKET A7325-H1000 FUEL HOSE VINYLE 10X14X10,000 22157-H1000 ASSY-ROTOR,HEAD 22301-H1000 VACUUM CONTROL ASSY 22157-H1000 ROTOR-HEAD 22157-H1000 HEAD-ROTOR 30537-H1000 PIN BALL W/DRAWAL LEVER (THREADED TY 43252-H1000 SEAL-OIL,REAR AXLE SHAFT A7515-H1800 FUEL HOSE VINYLE 6X13.5X10.000 A7515-H1800 FLEXIBLE HOSE C (L=470) A7515-H1800 FUEL HOSE 14917-H1902 TUBE (IDLE COMPENSATOR TO CONNECTOR) 22167-H2300 CAP CLAMP SET 22136-H2300 BRAKER PLATE ASSY 22750-H2300 SCREW SET 22750-H2300 KIT-SCREW 22750-H2300 KIT-SCREW 40052-H2500 ARM-KNUCKLE RH 40053-H2500 ARM-KNUCKLE LH 40052-H2501 ARM-KNUCKLE RH 40053-H2501 ARM-KNUCKLE LH 13001-H2700 CAM SHAFT 22119-H2700 SET-COLLAR 13001-H2700SV CAM SHAFT 13001-H2710 CAM SHAFT 65601-H3525 SET-HOOD LOCK,MALE & FEMALE 65601-H3525 ASSY-MALE,HOOD LOCK 16510-H3900 ASSY-MOTOR,VACUUM 16585-H3900 TUBE (SENSOR TO CONNECTOR) 14959-H3900 TUBE (SENSOR TO CONNECTOR) 16580-H3900 ASSY-SENSOR,TEMPERATURE 16582-H3900 STOPPER 16059-H3910 VALVE-POWER #150 16059-H3910 VALVE-POWER #50
30412-21000 DOWEL-TIMING 9.5 CASE LOCATING 16420-21000 SPACER-FUEL PUMP 23122-21000 PACKING 23121-21000 RETAINER-PACKING 23121-21000 RETAINER-PACKING 23122-21000 PACKING 30502-21000 BEARING-CLUTCH RELEASE 30624-21000 CUP-PISTON 34410-21000 TRUNION-GEAR SHAFT ROD 54324-21000 NUT 54324-21000 NUT-HEX SELF LOCK 62678-21000 SHIM-BRACKET 24438-21000 ROD-BATTERY,FIX 24440-21000 ROD-BATTERY,FIX 80577-21000 BOLT-SPECIAL TO FIX STRIKER 80970-21000 GROMMET-LOCK KNOB 62678-21000 SHIM-BRACKET BUMPER SIDE FIX BRACKET TO 62678-21000 SHIM-BRACKET BUMPER SIDE TO FENDER 24438-21000 ROD-BATTERY FIX A (NOT ADOPTED 24440-21000 ROD-BATTERY FIX C 80577-21000 BOLT-SPECIAL TO FIX STRIKER 80970-21000 GROMMET-LOCK KNOB 62678-21000 SHIM-BRACKET BUMPER SIDE 16420-21001 SPACER-FUEL PUMP 23150-21001 ASSY-PULLEY 23333-21001 SPRING-BRUSH 23333-21001 SPRING-BRUSH 80840-21001 COVER-DRAIN HOLE 80840-21001 COVER-DRAIN HOLE 17099-21002 GASKET-FUEL PUMP 23150-21002 ASSY-PULLEY 23150-21002 ASSY-PULLEY 74630-21002 HANDLE-SPARE WHEEL CLAMP 74630-21002 HANDLE-SPARE WHEEL CLAMP 80595-21003 KNOB-DOOR LOCK 80595-21003 KNOB-DOOR LOCK 22401-21004 PLUG-SPARK L44P(HITACHI) 23123-21005 RETAINER-BEARING 22162-21007 ASSY-CAP 22162-21007 ASSY-CAP 22401-21007 PLUG-SPARK L47P(HITACHI) 30537-21010 PIN-BALL WITHDRAWAL LEVER 41128-21010 BLEEDER (TOKICO) FOR FORE CYLINDER 41128-21010 BLEEDER 46038-21011 CAP-VALVE 41128-21011 SCREW-BLEEDER 46038-21011 PLUG-CYLINDER 32005-21100 COMP-SWITCH REVERSE LAMP 32005-21100 COMP.-SWITCH,4 TH 32005-21101 COMP-SWITCH REVERSE LAMP 32005-21101 COMP-SWITCH,4 TH 32005-21101 COMP-SWITCH REVERSE LAMP 65610-21400 ASSY-FEMALE HOOD LOCK 24420-21401 FRAME-BATTERY,FIX 76488-21600 CLIP-SILL MOULDING 76488-21600 CLIP-SILL MOULDING 00851-21610 WIRE-LOCK 41128-21900 SCREW-BLEEDER(NABCO) 41128-21900 SCREW-BLEEDER 44118-21910 ASSY-LEVER (TOKIKO) 44118-21910 ASSY-LEVER (TOKIKO) 32886-22000 WASHER-BODY BOLT 22132-22005 ASSY-CAM 16084-22010 WASHER 44108-22010 PISTON-CYLINDER (TOKIKO) 16439-22100 CLAMP-FUEL TUBE 16439-22100 CLAMP-HOSE 16439-22100 CLAMP-HOSE 16439-22100 CLAMP-HOSE 16439-22100 CLAMP-HOSE 16439-22100 CLAMP-HOSE 16439-22100 CLAMP-HOSE 16439-22100 CLAMP-HOSE 54313-22127 OIL-SUSPENSION STRUT (ATSUGI 360C 54313-22128 OIL-SUSPENSION STRUT (ATSUGI 1000 54313-22129 OIL-SUSPENSION STRUT (ATSUGI 360C 43066-22500 SEAT-CONNECTOR BRAKE HOSE 36528-22500 WASHER-PLAIN 36528-22500 WASHER-PLAIN 08124-23010 BOLT-HEX 08124-23010 BOLT-HEX WITH LOCK WASHER STAY TO HOOD 08134-23510 BOLT 08915-23610 WASHER FIXING PROTECTOR 08915-23610 WASHER FIXING PROTECTOR 08915-23610 WASHER-SPRING LOCK 08915-23810 WASHER-LOCK FIXING INSULATOR TO BRACKET 08915-23810 WASHER-LOCK M8 08915-23810 WASHER-LOCK 08915-23810 WASHER-LOCK FIXING TRANSMISSION 08915-23810 WASHER-LOCK 08915-23810 WASHER-LOCK FIXING TRANSMISSION 08915-23810 WASHER-LOCK 08915-23810 WASHER-SPRING LOCK 08915-23810 WASHER-LOCK UPPER 08915-23810 WASHER-LOCK LOWER 08915-23810 WASHER-LOCK REAR 00922-24000 RING-SNAP 08915-24010 WASHER-SPRING LOCK M10 08915-24210 WASHER-SPRING LOCK 08916-24210 WASHER-TOOTH 12 08911-24610 NUT
46100-26100 ASSY-SWITCH BRAKE INDICATOR 32829-26760 BALL-CHECKING 32829-26760 BALL-STEEL (7.938) 46056-27260 SPRING-VALVE INLET (NABCO/TOKIC 46032-27260 PIN-RELEASE INLET VALVE (NABCO) 46043-27260 PACKING(NABCO) 46079-27260 RING-"O"(NABCO) 46070-27260 RING-SNAP(NABCO/TOKICO) 46100-27260 COVER-DUST(NABCO/TOKICO) 30611-27260 SHIM T=1.6MM 30613-27260 SHIM T=0.5MM 30625-27260 PISTON 46070-27260 RING-STOPPER 46100-27260 COVER-DUST 46042-27260 PACKING 46079-27260 PACKING 46070-27260 RING-STOPPER 46100-27260 COVER-DUST 46042-27260 PACKING-VALVE 46100-27260 COVER-DUST 46079-27260 GASKET-PISTON STOPPER 46070-27260 RING-STOPPER 46100-27260 COVER-DUST 20602-27700 NUT-FIXING TUBE END 27075-27700 CONNECTOR-HEATER 32865-27700 KNOB-CONTROL LEVER 40225-27700 NUT-ROAD WHELL 40225-27700 NUT-ROAD WHEEL 44000-27700 ASSY-BRAKE REAR RH FOR FRONT DR 44010-27700 ASSY-BRAKE REAR LH FOR FRONT DR 44030-27700 ASSY-DISC REAR BRAKE LH 44020-27700 ASSY-DISC REAR BRAKE RH 44030-27700 ASSY-DISC REAR BRAKE LH 62663-27700 BOLT-BUMPER 62663-27700 BOLT-BUMPER,B 62663-27700 BOLT-BUMPER 62663-27700 BOLT-BUMPER B,BUMPER TO BRACKET 62663-27700 BOLT-BUMPER B BRACKET TO BUMPER 41100-27727 KIT-REPAIR WHEEL CYLINDER A 41100-27728 KIT-REPAIR WHEEL CYLINDER B 41124-28500 SEAL-PISTON 41127-28500 BOOT 41135-28500 RING-RETAINING 46075-28511 SPRING-PISTON 54313-28525 OIL-SUSPENSION STRUT (TOKICO 360C 46020-28600 SET-CAP OIL RESERVOIR(NABCO) 14011-29901 NUT-FIXING TUBE END 23500-29901 REGULATOR-VOLTAGE (HITACHI TL1 23500-29902 REGULATOR-VOLTAGE (HITACHI TLI 23500-29911 REGULATOR-VOLTAGE (MITSUBISHI
16400-A0600 ASSY-STRAINER FUEL 16439-A0600 CLAMP-HOSE FUEL STRAINER SIDE 46123-A0600 PIN-CLEVIS 86982-A0600 EYELET-'A'SET BACK 86983-A0600 EYELET-'B'SEAT BACK 86981-A0601 PLUG-SEAT BACK 16439-A0602 CLAMP-HOSE 16439-A0602 CLAMP-HOSE 96830-A0800 WASHER-PLAIN 38322-A0900 ASSY-BREATHER 38322-A0900 ASSY-BREATHER 46027-A1100 SPRING-VALVE 46029-A1100 SEAT-TUBE 46038-A1100 CAP-VALVE 46038-A1100 CAP-VALVE 65601-A2200 ASSY-MALE HOOD LOCK 65601-A2200 ASSY-MALE HOOD LOCK 65601-A2201 ASSY-MALE HOOD LOCK 65601-A2201 ASSY-MALE HOOD LOCK 41129-A2410 CAP-BLEEDER 41129-A2410 CAP-BLEEDER (TOKICO) FOR FORE CYLINDE 41129-A2410 CAP-BLEEDER 41129-A2410 CAP-BLEEDER(NABCO) 41129-A2410 CAP-BLEEDER(NABCO) 41129-A2410 CAP-BLEEDER SCREW 41129-A2410 CAP-BLEEDER SCREW 41129-A2410 CAP-BLEEDER 14875-A3000 CONNECTOR-VACUUM TO IN TAKE MANIFOLD 21200-A3001 ASSY-THERMOSTAT 82C 21200-A3005 ASSY-THERMOSTAT 88C FOR WINTER 11810-A3500 ASSY-CONTROL VALVE CRANK CASE EMISSIO 31065-A4000 CLAMP-VACUUM TUBE 26029-A4600 COVER-TERMINAL 46237-A4600 GASKET-CLUTCH HOSE TO CYLINDER T=1 26375-A4601 ASSY-BLADE WIPER 26029-A4601 COVER-TERMINAL 21060-A4605 FAN-COOLING D=330 FOR TROPICAL USA 22401-A4605 PLUG-SPARK BP-5ES(N.G.K) 22401-A4616 PLUG-SPARK BP-6ES(N.G.K) 22401-A4617 PLUG-SPARK 22401-A4704 PLUG-SPARK L47PW(HITACHI) 22401-A4705 PLUG-SPARK L45PW(HITACHI) 22401-A4706 PLUG-SPARK L46PW(HITACHI) 22401-A4706 PLUG-SPARK(L46-PW) 22401-A4707 PLUG-SPARK L47PW(HITACHI) 22401-A4725 SET-IGNITION(HITACHI) 22401-A4804 PLUG-SPARK L44PW(HITACHI) 22433-A5400 COIL-IGNITION (HITACHI) 22433-A5410 COIL-IGNITION (HANSHIN) 14911-A5500 TUBE-EVAPO CONTROL(L=80) 14910-A5501 ASSY-VALVE FLOW GUIDE 14913-A5501 TUBE-EVAPO CONTROL L=200 23100-A5501 ASSY-ALTERNATOR(HITACHI) 23108-A5501 ASSY-ROTOR 23102-A5501 ASSY-STATOR 14910-A5502 ASSY-VALVE FLOW GUIDE 22248-A5502 SEAL-DUST 46091-A6800 RESERVOIR-OIL,BRAKE,FOR DRUM 46091-A6800 RESERVOIR-OIL,BRAKE,FOR DISC 46027-A6900 SPRING-RESIDUAL VALVE
21060-N0100 FAN-COOLING,FOR TROPICAL USE 38322-N0100 ASSY-BREATHER 54324-N0100 NUT 54324-N0100 NUT-HEX SELF LOCK 46093-N0400 FILTER-OIL,FOR DRUM 46092-N0400 FILTER-OIL,FOR DISC 46093-N0410 FILTER-OIL 22110-N0901 ASSY-SWITCH, THERMOSTAT 76486-N1600 BOLT-SILL MOULDING 80595-N1600 KNOB-DOOR LOCK 80595-N1600 KNOB-DOOR LOCK 14910-N2200 ASSY-VALVE FLOW GUIDE 14910-N2202 ASSY-VALVE FLOW GUIDE 14910-N2203 ASSY-VALVE FLOW GUID 20720-N2225 KIT-SEALANT,EXH TUBE JOINT 23500-N3300 REGULATOR-VOLTAGE (HITACHI TLI 32851-N9000 PLUNGER-RETURN SPRING 32851-N9000 PLUNGER-RETURN SPRING 17310-P0100 PLUG-DRAIN 17310-P0100 PLUG-DRAIN 17310-P0100 PLUG-DRAIN 17310-P0100 PLUG-DRAIN 23193-P0100 TERMINAL-N 25235-P0100 ASSY-RELAY,HEATER,AUTO CHOKE 36406-P0100 PLATE-LOCK HAND BRAKE CABLE 17312-P0101 PACKING-DRAIN 17312-P0101 PACKING-DRAIN 17312-P0101 PACKING-DRAIN 17312-P0101 PACKING-DRAIN 17312-P0102 PACKING-DRAIN 17312-P0102 PACKING-DRAIN 17312-P0102 PACKING-DRAIN 17312-P0102 PACKING-DRAIN 87408-P2000 BOLT-SPECIAL CUSHION FIX TO BACK 87408-P2000 BOLT-SPECIAL CUSHION FIX TO BACK 21638-P2600 JOINT-TUBE 21625-P2600 BOLT-CONNECTOR,OIL COOLER 21626-P2600 WASHER-SEAL 31086-P2601 ASSY-GAUGE,OIL LEVEL 32703-P2622 ASSY-PINION,SPEEDOMETER 20630-P4400 RING-RUBBER MUFFLER CLAMP 46079-R1200 GASKET-PISTON STOPPER 46032-R1200 STOPPER-SECONDARY PISTON 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FI ST306- DRIFT-DRIVE PINION BEARING FOR DIFFEREN ST325- WEIGHT-SIDE BEARING ADJUST FOR DIFFEREN 13210-U0100 COLLET-VALVE 21430-U0100 ASSY-CAP PADIATOR 23100-U0100 ASSY-ALT.12V-35A (HITACHI LT135-13)(DE 23100-U0100 ASSY-ALTERNATOR 12V-35A (LT135-13) 23108-U0100 ASSY-ROTOR 23127-U0100 ASSY-COVER,REAR 23133-U0100 ASSY-HOLDER,BRUSH 23236-U0100 COVER-BRUSH 23230-U0100 DIODE 23102-U0101 ASSY-STATOR 23127-U0101 ASSY-COVER,REAR 23133-U0101 ASSY-BRUSH 44128-U0201 SCREW-BLEEDER (NABCO) 41129-U0201 CAP-BLEEDER (NABCO) 41128-U0201 SCREW-BLEEDER (NABCO) 41129-U0201 CAP-BLEEDER (NABCO) 46027-U0201 SPRING-VALVE 46029-U0201 SEAT-SPRING 41128-U0201 SCREW-BLEEDER 41129-U0201 CAP-BLEEDER SCREW 46090-U0201 RESERVOIR-OIL,FOR DRUM 46090-U0201 RESERVOIR-OIL,FOR DISC 46020-U0201 ASSY-CAP,OIL RESERVOIR 46091-U0502 RESERVOIR-OIL,FOR DISC 44128-U0512 SCREW-BLEEDER (TOKIKO) 41128-U0512 SCREW-BLEEDER (TOKIKO) 46090-U0512 PESERVOIR-OIL FOR DRUM 46090-U0512 RESERVOIR-OIL FOR DISC 46091-U0512 RESERVOIR-OIL FOR DISC 46020-U0512 ASSY-CAP,OIL RESERVOIR 41128-U0512 SCREW-BLEEDER 65610-U1702 ASSY-FEMALE HOOD LOCK 65610-U1702 ASSY-FEMALE HOOD LOCK 22433-U2000 COIL-IGNITION (HITACHI) 22120-U2001 ASSY-SWITCH WATER TEMP 22433-U2010 COIL-IGNITION (HANSHIN) 22460-U2200 RESISTER-IGNITION COIL (HITACHI) 44112-U4000 CUP-PISTON (NABCO) 44113-U4000 RING-SNAP (NABCO) 44124-U4000 COVER-DUST'A' (NABCO) 44141-U4000 SHIM-ADJUSTING 'A' (NABCO) 44142-U4000 SHIM-ADJUSTING'B' (NABCO) 44144-U4000 COVER-DUST'B' (NABCO) 44113-U4000 RING-SNAP (NABCO) 44124-U4000 COVER-DUST'A' (NABCO) 44141-U4000 PLATE-LOCK (NABCO) 44142-U4000 PLATE-BACK UP (NABCO) 44144-U4000 COVER-DUST'B' (NABCO) 44113-U4010 RING-SNAP (TOKIKO) 44124-U4010 COVER-DUST'A' (TOKIKO) 44141-U4010 SHIM-ADJUSTING'A' (TOKIKO) 44144-U4010 COVER-DUST'B' (TOKIKO) 44149-U4010 PLATE-'A' (TOKIKO) 44124-U4010 COVER-DUST'A' (TOKIKO) 44141-U4010 SHIM-ADJUSTING'A' (TOKIKO) 44149-U4010 PLATE-LOCK (TOKIKO) 44144-U4010 COVER-DUST'B' (TOKIKO) 46100-U5200 ASSY-SWITCH BRAKE INDICATOR
43070-H5000 SPACER RR AXLE 43215-H5000 BEARING RR AXLE 22100-H5900 DISTRIBUTOR (D411-59K)(ISO) L14 22100-H5900 ASSY-DISTRIBUTOR (D411-59K IS L14 22100-H5901 ASSY-DISTRIBUTOR L14 23100-H6200 ASSY-ALTERNATOR 12V 50A (LT150-05)FO
