R145
Revision as of 09:38, 23 February 2012; view current revision
Category: Differential
Hitachi R145 was used in 4WD applications as the rear final drive. Many applications used a 4-bolt rear cradle..
Murano Z50 electric coupling
N14, N15 Pulsar
N30 9710-0107 R'nessa
B15, M12, G10, N15, RB14, W11, B13, N14
C24, M12, JU30, P12, U30, VW11, W11
M12 with hydraulic coupling 0105-
K11 March with hydraulic coupling
T30 X-Trail with electric coupling
T30
N14 Pulsar
including RNN14 GTiR
Sources
Murano
N14, N15 Pulsar
B14, B15 Sunny
RB14
C24 9907- Serena (vanette)
K11 9911-0010 March CG10DE+CGA3DE
M12 9811-0105 Prairie Liberty
P12 0101- Primera
T30 0010 to 2007 X-Trail
JU30 9911- Besara
U30 9806- Presage
VW11 9809- Expert エキスパート
W11 9809- Avenir
T30
380
38300-8H500 FINAL DRIVE ASSY
38761-8H500 COUPLING ASSY-ELECTRIC
38421-4N200 CASE-DIFFERENTIAL
 C24,K11,M12,P12,T30,W11
38100-4N500 GEAR SET-FINAL DRIVE 37/15=2.466
38310-8H500 CARRIER COMPL-GEAR
38331-8H500 COVER-COUPLING
K11 March
38760-4N210 COUPLING ASSY-HYDRAULIC
Case
 CASE (CARRIER COMPL-GEAR)
38310-8H500 [electric coupling]
 T30
38310-4N500
38311-20E00
 N30 Rnessa
 JU30 9911-0108 KA24DE+YD25DDT
38310-4N500
  JU30 0108- QR25DE
38311-71Y00/38311-71Y02
 B13, B15, M12, G10, N14, N15, RB14, W11
Gearset
2.466
3.357
3.692
3.700
38100-CA000 GEAR SET-FINAL DRIVE 37/15=2.466 $617 USD
 C24,K11,M12,P12,T30,VW11,W11,JU30,U30
38100-11E65 48/13=3.692
 B15, G10, U30
38100-10E60 GEAR SET-FINAL DRIVE 47/14=3.357
 M12, N30, W11, U13
38100-03G10 GEAR SET-FINAL DRIVE 37/10=3.700
 B13, B14, N14, N15, RB14
LSD
Both Nissan and Cusco sell rear LSD
38760
38411-20R21 COUPLING ASSY-VISCOUS $584 USD
* superseded 38411-20R14
* N14 JDM
* M11 USA Axxess 0189- *4WD.KA24E.SGL.FA (R200?)
Cusco
MZ TYPE-RS No. LSD684 1.5 way Subaru BP/BL (2003-2009 Legacy/Liberty)
MZ 1-way
Coupling
The coupling takes the place of a center differential. These models have a totally different case, which is split on the axle centers.
Electric Coupling
The electric coupling, when not powered, allows the rear diff to free-wheel (FWD mode).
When fully powered, the propeller shaft powers the diff as normal.
The coupling is designed to work at any setting from non-powered to fully-powered, for various torque splits.
For this reason, operating as a RWD-only diff is complicated. You could use a relay and fully power it, but the failure mode would be to stop transmitting power.
Z50 USA Murano (CVT)
T30 JDM X-Trail GT
Gasket
Gear carrier (main housing) gasket
38320 GASKET-GEAR CARRIER
38353-U3000 $5 USD
* USA.S130+910+M10+M11
* JDM.M10+M11+B12+U12+910+U12+P10+C31+F30+C31+N13+R30+S12
999MP-A7007P K11 [w/fluid coupling] [split gaskets]
*C8320-00330 $22 Silicon Gasket
38320-01G03
38320-01G02 Gasket Gear Carrier $28 USD
38320-01G00
* R200/R180/R160/R145?
* JDM.N14,N15,B13,B14,B15,C22,C23,D21,D22,F23,E24,M12,VE24,WE24,
  G10,JU30,U30,N30,R20,R30,R33,RB14,S14,W11,W30,A31,C33,C34,
  R20,U13,WD21
