Hub
Revision as of 06:48, 19 December 2012; view current revision
Categories: Front Axle And Front Suspension | Brake System
The front wheel hub contains the Wheel Bearings. The brake rotor (or brake drum) is bolted to the hub.
drum hub vs. disk hub
click
The brake rotor bolts to the back of the hub
The hub slip over the spindle
D1 25mm
D2 15mm
hub on spindle
comparo
Specs
Drum Hub
B122 Disc Brake Hub
DRUM - ASSY-HUB ROAD WHEEL FRONT
  • B110: 40202-18051 DRUM BRAKE
  • B210: 40202-18000 DRUM 1974-1975
  • B210: 40202-H7405 DRUM 1976-1978 Japan
??? (is this drum or disc hubs?)
  • B210: 40202-H7425 DRUM 7510- Van Japan
  • B210: 40202-H7425 DRUM 1976-1978 Japan
DISC - ASSY-HUB ROAD WHEEL FRONT
  • B110: 40202-H1005 DISC BRAKE
  • B210: 40202-H1005 DISC 1974-1975 GX
  • B210: 40202-22000 DISC -0775 USA
  • PB210: 40202-22050 DISC 1974-1975
  • PB210: 40202-A0155 DISC 7510-
  • B210: 40202-A0155 DISC 0875- USA
  • B210: 40202-A0155 DISC 1976-1978 L16 Japan
  • B310: 40202-H7405 DISC, small rotor (Canada A12A)
  • B310: 40202-W5050 DISC, large rotor (A14/A15, A12A USA)
Grease Caps
B10, B110 and early B210 uses the smaller size dust cover
40234-18000 CAP-HUB FRONT WHEEL
Larger caps
40234-28500 CAP-HUB FRONT WHEEL
* B310 (both hub types)
* Late B210 (both hub types)
