Room Lamp
Revision as of 00:38, 12 April 2013; view current revision
The room lamp, also known a dome light.
Car
These parts are the same for both B110 and B210.
120Y
510 Lamp
510 lamp is a different style and bolts into B210, so may fit B110.
Pickup
Two wires:
- Red: bulb 12V
- Black: earth/ground
521 Lamp
Datsun 521 pickup (USA) uses the same Room Lamp as a 1200 Pickup. IKI brand.
26400-04100 ASS'Y-LAMP, room
26410-04400 ASS'Y-LAMP, room
* 26411-04100 LENS
* 26715-89900 BULB (12V 6W)
* 5-10813-1 SCREW-machine (2)
See Room Lamp Part Numbers
The room lamp has one side of the lamp (RL wire) always hot from the L wire of the fuse box. The switch has three positions:
  • Off
  • Auto (center)
  • On
In the auto position, the light is grounded by the Door Switch (BR wire in a-pillar). Usually only the driver's side door has a switch. In the ON position, it is grounded through the ground wire in the headliner.
