Rear Axle
Revision as of 03:32, 24 June 2007; view current revision
The Datsun 1200 used a leaf-spring live axle with an H145 differential. This is a Hitachi design with 145mm ring gear. It is a lightweight unit suitable to handle the torque from an A12 engine. Light weight is good. Heavy parts take more horsepower to accelerate.
Also see Rear Axle Swaps.
Differential Lubricant
  • the traditional "90 weight" gear oil
  • the newer 75W140 multi-weight gear oil
For maximum fuel economy, use a modern multi-weight gear oil.
The original specifications (which are still OK to use) are:
  • Specification: API GL-4MIL-L-2105
    • CHEVRON Multiservice Gear Lub. 75,80,90,140
    • ESSO Gear Oil GP80,90,140
    • MOBIL Mobilube EP or GX80-90, 90, 140
    • SHELL Spirax 75EP,80EP, 90EP, 140EP
    • SUNOCO Multipurpose GearLub. GL-480,90,140
    • TEXACO Universal Gear Lub.EP80,90,140
reference: Owners manual
OM%201971%201228%2000%200%20Cover_140.jpg Online Owner's Manual
Suppliers - USA
Rear Axle Seal
  • Nissan 43252-H1000 SEAL-OIL REAR AXLE SHAFT
Rear Axle Bearing
  • Nissan 43215-18000 BEARING-REAR AXLE
  • Nissan 43255-H1000 COLLAR-REAR AXLE BEARING
NOTE: 180 is B10 part number, so B10 and B110 should interchange
Differential Axle Bearing
1.1811 in. I.D; 0.6299 in. width; Fits H145 & H150.
Taper Bearing Assembly: Cone Length=0.6299" Bore=1.1811" Outer Diameter=2.4409" Width=0.6791" Cup Length=0.5512" Cone Radius=0.06" Cup Radius=0.06"}
Application: Alfa, Mitsubishi, Ford, Mazda, Nissan, Plymouth, Porsche, Subaru
PartsAmerica
  • SKF BR30206 - $16.99
  • BCA 30206 - $29.99
  • Motor City S30206 - $9.88
RockAuto.com
  • TIMKEN Part # 30206M - $14.96
  • BCA/NATIONAL Part # 30206 - $16.74
Pinion Seal
B110, through 1974 model year B210. Probably fits B10 as well.
[1]Partsamerica.com pinion seal[/url]
  • SKF Oil Seal #550219 $22.99
Pinion Bearing
Fits many cars, GM, Nissan, Isuzu, Mazda, Opel, etc
Taper Bearing Assembly: Cone Length=0.7874" Bore=1.1811" Outer Diameter=2.4409" Width=0.8366" Cup Length=0.6693" Cone Radius=0.06" Cup Radius=0.06"}
Rockauto
  • BCA/NATIONAL Part # 32206 - $19.84
Partsamerica
  • SKF BR32206 - $18.99
