Interior
Revision as of 03:16, 4 September 2015; view current revision
Category: Body
Datsun 1200 standard interior was elk-pattern black vinyl. Blue, Yellow, Ivory and Brown were also available, as well as fabric patterns.
Black was the original interior trim color. Regardless of exterior/interior color, blue vinyl floor mats were standard.
Black was exclusively used for Ute 1971-1978
Brown was exclusively used 1978-1988
Gray was exclusively used 1988-1994, along with black vinyl floor mats
Interior Trim
  • G9910-H7000 Shelf-parcel $63.67
  • 79911-H1000 Cover-parcel shelf
  • 73950-H1000 Sunvisor-gry $39.83
Front window - 2-dr sedan
  • 80260-H1000 Handle-vent R $19.67
  • 80261-H1000 Handle-vent L $19.67
Door
  • 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH NLA
  • 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH NLA
  • 80760-H1000 Handle-regulatr $24.00
Rear window - 2-dr sedan
  • 76828-H1200 Cover-hinge [rear window] $1.02 USD
  • 76870-H1200 Handle-window RR $39.17 USD
  • 76871-H1200 Handle-window RL $40.62 USD
    • 80234-H1000 WASHER-BRACKET PIVOT $5.83 USD
  • 76832-H1201 HINGE-SIDE WINDOW (4) NLA
Hinge Covers
Also consider B210 gray part:
  • 76828-H5300, 76828-H5301 COVER-SIDE WINDOW HINGE B210 [GRAY]
Sedan Trunk
  • 84820-H1000 HANDLE-TRUNK
  • 84810-H1001 Wthrstrip Trunk $53.73
Head Liner
The head lining covers and insulates the roof panel.
Kick Panel
Kick panel is the front side panel.
Package Tray
See Package Tray for Parcel Tray
Coin trays
The seat riser trim is the little plastic pockets next to the doors.
See Seats
Below-door Trim
  • 74921-H1100 COVER-FLOOR SIDE FRONT RH
  • 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LB-211
  • 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LH-20
  • 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13
  • 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LH-20
  • 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13
  • 74922-H1100 COVER-FLOOR SIDE FRONT LH
  • 74922-H7000 COVER-FLOOR SIDE FRONT LH (BLUE,LB-211
Parcel Shelf
Parcel shelf is the area above the rear seat, under that rear window.
The original Parcel Shelf is a black-painted thin fiberboard.
Often used to place speakers.
full
full
TRIM CLIP (10 needed for parcel shelf)
Rear Body Part Numbers
17 79910-H1001 ASSY-PARCEL SHELF SEDAN <x> 79910-H7000 [fireproof]
18 01553-00051 CLIP-PARCEL SHELF (10) 14Ø (from '70-September)
   76906-G0511 取付穴9Ø用 (until '70-September) [9 mm mounting hole]
19 79911-H1000 COVER-PARCEL SHELF SEDAN [Cloth trim]
20 79912-H1000 PLUG-PARCEL SHELF SEDAN (4)
Raw Parts List
  • 093 001 76900-H1301 ASSY-FINISH,BODY SIDE,RH YELLOW 1 SEDAN 2 DOOR(DX) 1270-
  • 093 001 76900-H1200 ASSY-FINISH,BODY SIDE,RH BLACK(#1742) 1 SEDAN 2 DOOR -
  • 093 001 76900-H7000 ASSY-FINISH,BODY SIDE,RH (BLUE,LB-211 1 SEDAN 2 DOOR 0772-
  • 093 001 76900-H7001 ASSY-FINISH,BODY SIDE,RH (BEIGE,LH-20 1 SEDAN 2 DOOR 0772-
  • 093 001 76900-H7002 ASSY-FINISH,BODY SIDE,RH (BLACK,LG-13 1 SEDAN 2 DOOR 0173-
  • 093 002 76901-H1200 ASSY-FINISH,BODY SIDE,LH BLACK(#1742) 1 SEDAN 2 DOOR -
  • 093 002 76901-H7002 ASSY-FINISH,BODY SIDE,LH (BLACK,LG-13 1 SEDAN 2 DOOR 0173-
  • 093 002 76901-H7000 ASSY-FINISH,BODY SIDE,LH (BLUE,LB-211 1 SEDAN 2 DOOR 0772-
  • 093 002 76901-H1301 ASSY-FINISH,BODY SIDE,LH YELLOW 1 SEDAN 2 DOOR 1270-
  • 093 002 76901-H7001 ASSY-FINISH,BODY SIDE,LH (BEIGE,LH-20 1 SEDAN 2 DOOR 0772-
  • 093 003 80919-89900 CLIP-DOOR FINISH 4 SEDAN 2 DOOR -
  • 093 004 76911-H1100 CLOTH-WINDSHIELD PILLAR,RH GRAY(#1740) 1 SEDAN(DX) -
  • 093 004 76911-H1101 CLOTH-WINDSHIELD PILLAR,R.H GRAY(#1740) 1 SEDAN(DX) - 2 76911-H1100
  • 093 005 76912-H1101 CLOTH-WINDSHIELD PILLAR,LH GRAY(#1740) 1 SEDAN(DX) - 2 76912-H1100
  • 093 005 76912-H1100 CLOTH-WINDSHIELD PILLAR,LH GRAY(#1740) 1 SEDAN(DX) -
  • 093 006 76951-H1100 PAD-WINDSHIELD PILLAR 2 SEDAN(DX) -
  • 093 007 76913-H1300 CLOTH-CENTER PILLAR,RH,GRAY (#1740) 1 SEDAN 2 DOOR(DX) -
  • 093 007 76913-H1301 CLOTH-CENTER PILLAR,RH,GRAY (#1740) 1 SEDAN 2 DOOR(DX) - 2 76913-H1300
  • 093 008 76914-H1300 CLOTH-CENTER PILLAR,LH GRAY (#1740) 1 SEDAN 2 DOOR(DX) -
  • 093 008 76914-H1301 CLOTH-CENTER PILLAR,LH,GRAY (#1740) 1 SEDAN 2 DOOR (DX) - 2 76914-H1300
  • 093 009 76953-H1300 PAD CENTER PILLAR 2 SEDAN 2 DOOR(DX) -
  • 093 010 76917-H1200 ASSY-CLOTH,REAR PILLAR,RH GRAY(#1740) 1 SEDAN 2 DOOR -
  • 093 010 76917-H1201 ASSY-CLOTH,REAR PILLAR,RH GRAY(#1740) 1 SEDAN 2 DOOR - 2 76917-H1200
  • 093 010 76917-H7000 ASSY-CLOTH,REAR PILLAR,RH (BEIGE) 1 SEDAN 2 DOOR 0772-
  • 093 011 76918-H1200 ASSY-CLOTH,REAR PILLAR,LH GRAY(#1740) 1 SEDAN 2 DOOR -
  • 093 011 76918-H1201 ASSY-CLOTH,REAR PILLAR LH GRAY(#1740) 1 SEDAN 2 DOOR - 2 76918-H1200
  • 093 011 76918-H7000 ASSY-CLOTH,REAR PILLAR,LH (BEIGE) 1 SEDAN 2 DOOR 0772-
  • 093 012 76957-H1200 PAD-REAR PILLAR 2 SEDAN 2 DOOR -
  • 093 012 76957-H7000 PAD-REAR PILLAR 2 SEDAN 2 DOOR 0772-
  • 093 013 08520-51220 SCREW-TAPPING M5 4 SEDAN 2 DOOR -
  • 093 014 76921-H1000 WELT-BODY SIDE BLACK #698 2 SEDAN 2 DOOR -
  • 093 015 76922-H1200 WELT-SIDE WINDOW BLACK #698 2 SEDAN 2 DOOR -
  • 093 016 96502-H1001 ASSY-ASH TRAY,REAR 1 SEDAN -
  • 093 017 08520-51220 SCREW-TAPPING 1 SEDAN -
  • 094 017 79910-H1001 ASSY-PARCEL SHELF 1 SEDAN -
  • 094 017 79910-H7000 ASSY-PARCEL SHELF 1 SEDAN 0772- 0 79910-H1001
  • 094 019 79911-H1000 COVER-PARCEL SHELF 1 SEDAN -
