A15 Industrial Engine carbureted 65 hp OR A12 Industrial Nissan Engine 32hp
A15 governer $1009 2002 PowerVac II (48hp) 2002 Performer (48hp) 2002 Performer 405 (48hp)
Everest truckmount A15 Zenith EFI fuel injection (ZEEMS)
2002 Nissan A15 with CAL emissions
post
Zenith Fuel Injection
post
Zenith ECU
post
Zenith Power Products
http://zenithpp.com/engines_a15.htm
Intermittent output (SAE Gross J1349) 46 HP/3,600 rpm Continuous output (SAE Gross J1349) 39 HP/3,600 rpm Peak torque (SAE Gross J1349) 11 kg-m (80 ft-lb)/2,200 rpm Minimum fuel consumption 225g/Hp-hr (0.496 lb/HP-hr)/3,200 rpm Fuel and type Gasoline, 4-cycle, O.H.V. Cylinder arrangement 4 in-line Combustion chamber Wedge shape Bore x stroke 76mm x 82mm (2.99 x 3.23 in) Total piston displacement 1,487 cc (90.74 cu in) Compression ratio 9.0 : 1 Length x width x height (standard model) 527.8 x 530.8 x 576.3mm (20.78 x 20.90 x 22.69 in) Dry weight (standard model)* 103kg (227 lb)
