Dropping Resistor
Revision as of 22:52, 6 June 2016; view current revision
Category: Fuel Injection
A Dropping Resistor pack is used to lower the current used by the Fuel Injectors. It is one unit with four resistors inside.
A14E
A14 EGI fuel injected engine
22698-N4202 RESISTOR-DROPPING -0780 $60.65 USD
22698-W1401 RESISTOR-DROPPING 0880- <>22698-W1411 <5> 22698-D0300
01451-00171 SCREW (2)
22698-N4202 (JECS A15-000571)
Spec
10 watt
7 ohms (6.8 ohm nominal)
N4202 8-wire connector
22698-N4202 is used by:
* EUROPE
  S130 280ZX L28E engine
  S110 Silvia L18E
* USA
  S110 200SX Z20E
* JAPAN
  B310 A14E
  250 Y44E V8 Nissan
  S110 Silvia Z18E+Z20E
Isuzu Trooper 2.6 4ZE1
A15E
A15 EGI engine
22698-W1401 <> 22698-D0300
* B310 A15E
* K10.3HB.T,910.(Z18E#+Z20E),B11.(E15E+E15ET),N12.E15T,R30.(Z20E+FJ20E),S110.(Z18E+Z20E+FJ20)
W1401 4-resistor pack???
22698-W1401 source:
* USA
  Pulsar NX 1983-1985 E15T
  S110 200SX Z20E USA
  N12 Pulsar E15ET USA
* EUROPE
  910 Bluebird Z20E
  N12 Cherry E15ET
* JAPAN
  K10.3HB.T
  910 Bluebird (Z18E#+Z20E)
  B11 Sunny E15E+E15E
  N12 Pulsar E15T
  R30 Skyline (Z20E+FJ20E)
  S110 Silvia/Gazelle (Z18E+Z20E+FJ20)
JECS
22698 RESISTOR-DROPPING
JECS A15-000J01
JECS A15-000G02
* 2-wire
* fuel pump resistor
JECS A15-000A00 2-wire
* 1990 KGN13 GA16I
JECS A15-000850 3-wire?
* KEN13 CA16DE
22698-36F00 (JECS A15-000G01)
* S13(S20DE+SR20DET+CA18DE+CA18DET)
* 6-pin squircle connector (pin 5 missing)
22698-N4202 (JECS A15-000571) $60.65 USD
* B310.A14E, 250.Y44E, S110.(Z18E+Z20E)
