DFC306
Revision as of 02:36, 8 March 2017; view current revision
Categories: Fuel System | Hitachi 306 Carburetor
Hitachi DFC306 is an electrically controlled feedback carburetor, used on A12 engine for Sunny Truck beginning October 1989.
DFC306 is the carburetor on 1989-1994 JDM A12 engines. It requires a special water heated Intake Manifold.
At first glance, it looks like other A-series carburetors with automatic choke (DCH306-series), but it has large electrical connectors
The most obvious feature may be this extended flange, with electric valve on one end, and water-contact area on other end
ID - behind sight-glass
Connector 1
Lower Valve
Mixture Control Solenoid (MCS) Valve
Connector 2
IACV-FICD SOLENOID VALVE
Idle Air Control Valve - FICD
Electric Choke
ECU
Factory Nissan 1200 ECU controls the electronic feedback carb via input from O2 sensor.
22604-95W00-1.jpg 22604-95W00-2.jpg 22604-95W00-3.jpg 22604-95W00-4.jpg 22604-95W00-5.jpg
22604-95W00
FBM-N13
<4-digit serial number>
ECU Control
ECU takes input signals from engine including water temp and O2 sensor and adjust the air/fuel mixture via the carburetor solenoid.
Carburetor electrical connector includes the automatic choke wire and Feedback Solenoid wires
Model: DFC306-26
Air horn entrance (inside diameter - outside diameter) 54-59 mm
Primary nozzle system (primary) secondary side (secondary)
Zenith Stromberg protruding type
Throttle Bore (mm) 26/30
Venturi (mm) 23/27
Venturi in diameter (inner - outer diameter) (mm) - 13-16
Venturi small diameter (inner - outer diameter) (mm) 8-16 7-10
Nozzle diameter (inner diameter - outside diameter) (mm) 2.1-3.0 2.8-4.0
92 main jet size 120 (# engraved)
Diameter 43 80 slow jet (# engraved)
Economizer diameter bleed 95 140 (# engraved)
90 main jet diameter correction (# engraved) -
Slow diameter air bleed correction for 230 (# engraved) -
Main air bleed size 70 60 (# engraved)
155 slow air bleed size 80 (# engraved)
All 閉角 degree throttle valve 9 20 (degrees)
Float chamber fuel pressure (kg/cm2) 0.24
Float level standard (from the top of the float chamber) (mm) 21
Idle port (mm) 1.6
Opening fast idle (dimension G) 1.35 (0.84) (degrees)
Auto choke choke system
Two-stage diaphragm complete explosion
爆開 complete degree automatic choke at low temperatures
* (dimension R) 25 (1.66) (degrees)
At high temperatures 33 (2.48) (degrees)
Choke set temperature (℃) 16
Manifold
Water-heated carburetor requires a special manifold.
1989-up Datsun 1200 manifold with extended-length carb flange
Applications
DFP306-5
DFC306-3  16010-11M07 Nissan B11 Sunny E15S.MT-(GL,LT).F5 8410-8412
DFC306-3A 16010-11M08 Nissan B11 Sunny E15S.MT-(GL,LT).F5 8412-
DFC306-4  16010-12M07 Nissan N12 Pulsar E15S.AT 8403-8412, B11 E15S.AT 8410-8412
DFC306-4A 16010-12M08 Nissan N12 Pulsar E15S.AT 8412-8604, B11 E15S.AT 8412-
DFC306-4B 16010-12M09 Nissan N12 Pulsar E15S.AT 8604-
DFC306-5  16010-52A00 B12 Sunny E15S.2WD.MT 8509-8601
DFC306-5A 16010-52A01 B12 Sunny E15S.4WD.MT 8509-8601, E15S.MT 8601-8604
DFC306-5B 16010-52A02 B12 Sunny E15S.MT 8604-8709
DFC306-6  16010-52A10 B12 Sunny E15S.2WD.AT 8509-8601
DFC306-6A 16010-52A11 B12 Sunny E15S.4WD.AT 8509-8601, E15S.AT 8601-8604
DFC306-6B 16010-52A12 B12 Sunny E15S.AT 8604-8709
DFZ306-31 16010-47A05 VB11 AD Van E15S.MT 8805-
DFC306-46 16010-19B00 Nissan K10 Micra MA12S (MT.F5)
DFC306-46
K10 Micra carburetor
th_4431_1.jpg th_4431_2.jpg th_4431_3.jpg th_4431_4.jpg th_4431_5.jpg th_4431_6.jpg th_4431_7.jpg th_4431_8.jpg th_4431_9.jpg
th_DFC306-46a.jpg th_DFC306-46b.jpg th_DFC306-46c.jpg th_DFC306-46d.jpg th_DFC306-46e.jpg th_DFC306-46f.jpg
Vanette
C22 Vanette used a similar feedback carburetor, which may be a DFC306 or a DCZ306.
