Heater
Revision as of 01:58, 23 December 2007; view current revision
Heater was optional in the Standard model for most countries. All USA models came with a heater (by law).
Coolant Flow to Heater
Operation
USA 1972 Owners manual (see pages 18-19 for details):
Comfort and Convenience
No-heater models
Ventilation for models originally equipped with No Heater.
The valve has only thre positions: CLOSE, HALF OPEN and FULLY OPEN
TIP: Pull heater level out to switch fan speeds.
Heater Inspection
Heater core:
  • Leaks (before removing, check for leaks in passenger area, under carpet, on firewall cardboard, etc)
  • Flow (ensure it is not plugged). You can test similar to radiator blocked test
  • Clean out debris in exterior of core
Hoses: Check for cracks, overly soft hoses, tight clamps
Flow valve: ensure it opens & closes easily through entire range. Also check linkage for easy and complete movement (before taking apart)
Air ducts: Ensure they are clean and connected properly
Electrical: Ensure fan spins at both High & Low speed
Coolant Thermostat: Test
