Zenith ZEEMS fuel injection for Nissan A15 engine (injector and fuel inlet at top)
* Fuel pump: Walbro GSL395 (40-50 psi) * 15 psi injector * 15 psi fuel regulator * Throttle body has coolant connections * Uses stock Sunny Truck electronic distributor 22100-G5110 * ECT sensor goes in back of head (heater hose port)
PROCHEM SERVICE PARTS LIST ZEEMS I A15 CERTIFIED FUEL SYSTEM ITEM # PART DESCRIPTION SERVICE PART NUMBER 1 THROTTLE BODY ASSY. W/O ECU C282-20098 2 GASOLINE INJECTOR (O-RINGS INCL.) C282-366 2A O-RING KIT (GASOLINE INJECTOR & FUEL PRESSURE REG.) C282-14 3 GASOLINE FUEL PRESSURE REGULATOR C282-281 4 AIR TEMPERATURE SENSOR C282-6 5 MANIFOLD ABSOLUTE PRESSURE SENSOR (MAP) C282-239 6 MANIFOLD GASKET KIT C282-362 7 ENGINE COOLANT TEMPERATURE SENSOR (ECT) C282-298 8 MANIFOLD ADAPTOR KIT W/ HARDWARE & GASKETS C282-347 9 HEAT SHIELD B190-176 10 OXYGEN SENSOR C282-355 11 ENGINE WIRING HARNESS E784-161 12 GASOLINE FUEL PUMP C282-238 13 GASOLINE FUEL FILTER (3/8" BARB) C282-224 14 ENGINE CONTROL UNIT (ECU) C282-326-44
* KIT, GSKT, MANFLD * HARNESS, ENG, A-15, EFI, ZEEMS * ASSY, THROTTLE BDY, W/O ECU * SENSOR, COOLANT, A15, EFI * SENSOR, AIR TEMP, A15, EFI * SENSOR, MAP, A15, EFI * ECU, NISSAN, A15, EFI * FILTER, FUEL, EFI * PUMP, FUEL, EFI * SENSOR, OXY, A15, EFI * O-RING KIT, FUEL PRESS & INJ * REGULATOR, FUEL PRESSURE * INJECTOR, GASOLINE (O-RING INCL.)
Zenith ECU
A15 Industrial Engine
Zenith Power Products Industrial Engine http://zenithpp.com/engines_a15.htm Intermittent output (SAE Gross J1349) 46 HP/3,600 rpm Continuous output (SAE Gross J1349) 39 HP/3,600 rpm Peak torque (SAE Gross J1349) 11 kg-m (80 ft-lb)/2,200 rpm Minimum fuel consumption 225g/Hp-hr (0.496 lb/HP-hr)/3,200 rpm Fuel and type Gasoline, 4-cycle, O.H.V. Cylinder arrangement 4 in-line Combustion chamber Wedge shape Bore x stroke 76mm x 82mm (2.99 x 3.23 in) Total piston displacement 1,487 cc (90.74 cu in) Compression ratio 9.0 : 1 Length x width x height (standard model) 527.8 x 530.8 x 576.3mm (20.78 x 20.90 x 22.69 in) Dry weight (standard model)* 103kg (227 lb)
governor
Throttle body bolts to adapter on stock manifold
IAT (Intake Air Temperature) in intake tube
MAP sensor bolts to back of throttle body
