Datsun 1200 uses two front brake hoses, one per side. And a single rear hose. These are flexible rubber hoses. Sometimes called "soft lines" to distinguish them from the "hard" metal brake lines.
[edit]
Front Brake Hoses
[edit]
Fitting
The front brake hoses have a slot in each end fitting. This slot takes a C-clip to secure the hose.
One end is clipped to a bracket on the strut
The other end is clipped to a bracket on the inner fender
[edit]
Nissan [drum or disc type, single or tandem] * 46202-H7025 ASSY-HOSE BRAKE FRONT L=280 (2) $21 USD ** superceded 46202-89913 ASSY-HOSE BRAKE FRONT L=280
Beck Arnley 0730267 Rockauto.com* Length=11" End A Size=M10X1 End B Size=M10X1 RAYBESTOS BH36892/4536892 DORMAN H96862 ACDELCO 18J2188, 18J126, 19173109
Interchange * 1971-1973 Datsun 1200 * 1970-1978 Datsun S30 240Z/260Z/280Z * 1982-1986 Nissan N12 Pulsar NX * 1983-1986 Nissan B11 Sentra
NOTE: B210 requires 11.7" brake hoses Wagner F96549 Rockauto.com * B210 * B110 * etc * Replaces Nissan 46202-89915,46202-H7200,46212-01A15
[edit]
Rear Brake Hose
[edit]
Rear Hose Fitting
The rear hose (A) goes from the body to the Rear Axle.
On the axle, it screws into the Rear Splitter
[edit]
Rear Hose Part Numbers
Nissan 46201-H7200 Hose-brake $27 USD * superceded 46201-89918 ASSY-HOSE BRAKE REAR L=330
* Length=13.18" End A Size=M10X1 End B Size=M10X1 RAYBESTOS BH36866 DORMAN H36866 BECK/ARNLEY 0730879 Rockauto.comInterchange * 1971-1973 B110 * 1974-1978 B210 * 1977-1979 S10 * 1979-1983 S130 * 1978-1981 A10 wagon, rear * 1977-1981 810 * 1982-1984 910 Maxima/810
