Cigarette Lighter
Revision as of 09:34, 7 December 2018; view current revision
Cigarette Lighter, now useful for 12V accessories power. It is on a 15 AMP fuse, so can power a 250 watt inverter.
Original 1200 style
Middle element is for early Datsun 1200, outer for late 1200 pickup
16806.jpgAlbum 16806
Lighter body fits into Dash panel and the threaded portion clamps it tight to the panel.
23733.jpgAlbum 23733
The ground is provided by the metal contact of body with Dash.
27181.jpgAlbum 27181
Element
* B5330-H1001 ELEMENT-cigarette lighter $8.08
* B5330-H3101 ELEMENT-cigarette lighter 1972 JDM
Blocking plate for delete option
* 24250-89973 PLUG-cigarette lighter STD $1.50
Complete assemblies:
* 25330-H1000 LIGHTER COMP-cigarette early DX
** superceded by B5331-H5001 $23.80
*: Also Sunny Truck -7803
* 25330-H3100 LIGHTER COMP-cigarette DX 1972
* 25330-H3101 LIGHTER COMP-cigarette (from '72-10) DX
* 25330-B8001 B120 7804-8109
* 25330-G1900 B120 8110-
** 25335-89950 ELEMENT ASSY-CIGARETTE LIGHTER B120 8110- $16.00
** 25338-89900 PLATE-EARTH, CIGARETTE LIGHTER B120 8110-8109 $6.60
16809.jpgAlbum 16809
Illuminated with bulb, JDM GL, GX (including PB110)
* 25330-H2000 LIGHTER COMP-cigarette with bulb early
* 25330-H3400 LIGHTER COMP-cigarette 1972
* 25330-H3401 LIGHTER COMP-cigarette (from '72-10)
Illuminated
B5331-H5001
26654.jpgAlbum 26654 26655.jpgAlbum 26655 26656.jpgAlbum 26656
Comparison
Looks very similar to B110
25330-H5001 Illuminated (note wire)
risebike2000-img600x450-1314431570xjxofi46132.jpg risebike2000-img600x450-1314431570pkxdjr46132.jpg risebike2000-img600x450-1314431570c02rh746132.jpg
25330-H5001
B211
Nissan
Nissan 25331-89950 Cigarette Lighter
*Replaces: 25330-W0509, 25330-W2400
 25331-89951, 25331-89958, B5331-89958, 25330-N8200
26529.jpgAlbum 26529
620
25330-B5002
600x450-2008050700025.jpg 600x450-2008050700024.jpg 600x450-2008050700026.jpg
The Cigarette Lighter has a single wire connection, a Blue (L) wire that comes out of the middle of the instrument panel wiring harness. It is grounded through the metal frame of the dash.
L - Blue wire +12V (round bullet connector)
Not the longer LW (Blue/White stripe) which is adjacent
Since it is powered directly through the Fuse Box, the lighter socket works even when the key it out of the ignition.
Lighter - blue (L) wire
Wiring Diagram
[[[Template:Topic]] discussion]
Roadster 'CL'
