The Datsun A12 engine is the most common A series engine to be found. They are commonly found in most countries and were fitted to the B110, B210, & B310 chassis, known as the Datsun/Sunny 1200,[B110] Sunny/120y, [B210] & Sunny/120Y [B310]. The US model B210 [B210] & model 210 [B310] did not use the A12 engine.
All A series engine blocks, from the 7/73, were modified with a different method of providing oil to the camshaft, the distributer moved back, both engine mount brackets moved back 40mm and the altenator swapped from a low left position to a high right one. This was done to make room for an airconditioner compressor mounting point in the former alternator mounting area.
Specifications:
