A strut tower bar is a cool-looking piece of hardware that ties the two strut towers together. Also known as strut bar, dampener, damper bar, strut brace, or Monte Carlo bar. The performance theory is that it reduces chassis deformation on hard cornering.
Album 25378
B110 strut-top bolt circle is the same as other Nissans: 122mm diameter
Track 1200s will crack at the back of the strut towers. Not needed on a street car.
The brace can be as simple as a single piece of tubing
Album 650
Low and high versions
* Flat bar
* Round bar
* Round with taper ends
* Square section tube
jeffroj taper-end bars
Album 17946 Upload click to view
high mounts point for extra clearance
Album 17177 Album 16855
high-bend bar for extra clearance
Album 4700
square tube
Album 12329 Album 15854 Album 2443
Post 332487 Post 358288
Vendors
Bprojects
Bprojects
Album 14223
Titan
Album 15878
eeeCustoms
Album 22268
Nissan Prince Sporty Kit
99930-7110P
Album 2825
boofhead
Album 13790 Album 12888 Album 10977 Album 10978 Album 10957
Album 10364 Album click to view
Album 10369 Album 10079
Strut Top bar ends
Album 10100 Album 10182 Album 10183 Album 10184 Album 11586
Nismo
Nismo
Cusco
Cusco Type ST steel shaft クスコ タワーバー (part number 204 510 A) - clears A14/A15 engine
Album 25575
Album 4053
Mad Dat
Maddat Strut Brace
Maddat Tri-bar Strut Brace
Post 432419
Fumiya
Fumiya
Album 16531 Album 16532 Album 18839 Album 19397 Album 19398 Album 19399 Album 20008
low-rise
Album 19126 Album 19127
hi-rise for clearance
Album 19946 Album 19947
Toyota
Album 1609
Dimensions
1200 strut-top bolt circle: 122mm diameter
Album 17945
B110/B120 strut width center-to-center: 936 mm (36.85 inch)
Album 22877
Album 10017
Adjustable
Post 380888 Post 258967 Post 258967 Post 288413
Stiffening Bars
engine damper
Album 15859
Crossmember bar
Album 25646
Coupe rear body stiffener
Album 25645
Rear shock tower bar
Album 25647 Album 25648
More Photos
Album 1653 Album 1936 Album 2000
Pantel B310
Album 2400 Album click to view Album click to view
V8
Album 2672
Album 2812
510
Album 4064
sticks
Album 6718
modified Nismo bar
Album 4011 Album 9430
Album 10987 Album 12909
Laney
Album 13492
frankthedolphintrainer - extra clearance for CA18DE
Album 16510 Album 16511 Album 16512 Album 16854 Album 16855
Spreader bar
Album 19090
Strut tower-to-firewall
Album 20810
levey
Album 21121
Album 21861 Album 21862
Album 25373
strut brace, tower bar,strut bar,dampener,damper bar,brace,Monte Carlo bar not steering
