Part 1 - Engine, Clutch, Chassis Part 2 - Body, Options
Also see: Master Parts Catalog
Introduction
Index
Engine
Engine Electrical
Clutch, Transmission & Final Drive
Chassis
051 Engine Mounting 052 Fuel Tank (up to '73-2) 053 Fuel Tank (from '73-3) FUEL PIPING 054 Accelerator CHOKE CONTROL 055 Exhaust Tube & Muffler 056 Radiator 057 Wiring (57-A) Electric Unit (57-B) & SWITCH, ROOM HEATER, RADIO, CLOCK 058 Meter 059 Instrument Switch 060 Windshield Wiper 061 Windshield Washer 062 Head Lamp FRONT COMBINATION LAMP, SIDE FLASHER LAMP, ROOM LAMP 063 Rear Combination Lamp LICENCE LAMP 064 Clutch Pedal & Operating CLUTCH WITHDRAWAL LEVER, CLUTCH PEDAL 065 Remote Control (3 Speed) REMOTE CONTROL LEVER 066 Hand Brake Control 067 Hand Brake Linkage 068 Propeller Shaft (S-all) [short body, one-piece shaft] 069 Propeller Shaft (L-all) [long body, two-piece shaft] 070 Front Road Wheel FRONT HUB & DRUM, WHEEL BALANCE WEIGHT 071 Front Brake WHEEL CYLINDER REPAIR KIT 072 Rear Axle Case & Shaft REAR ROAD WHEEL 073 Rear Drum Brake WHEEL CYLINDER REPAIR KIT 074 Brake Master Cylinder BRAKE MASTER CYLINDER REPAIR KIT 075 Single Brake Master Cylinder (up to '73-2) 076 Tandem Brake Master Cylinder (Tokico) (from '73-3) REPAIR KIT (TANDEM TYPE) (TOKICO) 077 Tandem Brake Master Cylinder (Nabco) (from '73-3) REPAIR KIT (TANDEM TYPE) (NABCO) 078 Brake Piping 079 Brake Pedal 080 Steering Gear 081 Steering Linkage 082 Steering Wheel 083 Front Axle & Suspension FRONT AXLE, FRONT SUSPENSION 084 Front Suspension Strut FRONT SPRING, FRONT SUSPENSION STRUT 085 Rear Suspension REAR SUSPENSION, SHOCK ABSORBER 086 Spare Wheel Hanger
Body & Options
See Part 2 - Body, Options
