Sedan Taillights
Revision as of 06:03, 11 March 2025; view current revision
<-- back to Taillights
1970 vs Facelift
JDM USA EUR
All trims use the same taillights. STD and GX use the same units
11336.jpgAlbum 11336 750.jpgAlbum 750
#H10 Japan and #H16 North America tail light have Red blinkers, instead of Yellow/Orange
20733.jpgAlbum 20733
#H19 Australia/Europe lenses have Orange for the blinkers
20738.jpgAlbum 20738
LENS
20734.jpgAlbum 20734
RIM
20743.jpgAlbum 20743
PACKING (rubber seal: lens-to-body)
20736.jpgAlbum 20736
HOUSING (available as complete Combination Lamp Assembly)
20737.jpgAlbum 20737
PB110
H28 PB110 sedan - similar to B110 coupe, but longer
25536.jpgAlbum 25536
Facelift
H31 1972 Japan-market (facelift) models had new tail lamps:
20729.jpgAlbum 20729 20715.jpgAlbum 20715
1524.jpgAlbum 1524 1975.jpgAlbum 1975
20730.jpgAlbum 20730 20731.jpgAlbum 20731 20732.jpgAlbum 20732
26550-H3101 LAMP ASS'Y-rear combination (R.H.)
26555-H3101 LAMP ASS'Y-rear combination (L.H.)
* 23W bulb (4)
* 23/8W bulb (2)
* 3.4W bulb (2)
26552-H3101 RIM ASS-Y (2)
26553-H3101 PACKING ASS'Y (2)
26551-H3101 LENS ASS'Y (R.H.)
26556-H3101 LENS ASS'Y (L.H.)
IKI 4034
Clear Sedan
Just add one white, one red, and one amber LED bulb.
Levy production
21117.jpgAlbum 21117 21563.jpgAlbum 21563 21158.jpgAlbum 21158 21119.jpgAlbum 21119 21116.jpgAlbum 21116
NOTE: Not legal for road use, as they do not have a reflector or approved lens pattern.
Custom Sedan
Round
Coupe On Sedan
Coupe taillights on sedan | Compare to #Facelift
5494.jpgAlbum 5494 1524.jpgAlbum 1524 3815.gifAlbum 3815
H10
H10 is the original type taillight, designed for the Japanese domestic market. Four bulbs/side. No Yellow/Amber in lens. Used only by Japan/asia market. Looks like #H16 but has four bulbs per side (USA has only 3 bulbs/side).
JAPAN market - 4 bulb
26550-H1001 ASS'Y-LAMP, rear combination (R.H.)
26555-H1001 ASS'Y-LAMP, rear combination (L.H.)
* 23W bulb (2 per side)
* 23/8W (1 per side)
* 3W (1 per side)
26552-H1001 ASS'Y-RIM (2) $38.82 USD
26553-H1000 ASS'Y-PACKING (2) $18.33 USD
26551-H1001 ASS'Y-LENS (R.H.) NLA
26556-H1001 ASS'Y-LENS (L.H.) NLA
26563-H1000 ASS'Y-HARNESS (R.H.)
26568-H1000 ASS'Y-HARNESS (L.H.)
RIM
H16
H16 is the taillight modified for North America lens standards. On the outside looks just like JAPAN #H10 (no yellow section)
  • lens reflection differs
  • Uses three bulbs per side vs JAPAN 4-bulb
USA tail light have RED-RED-CLEAR
P1020699.jpg 20733.jpgAlbum 20733
USA - 3 bulb
26550-H1902 ASSY-LAMP REAR COMBNATION RH (ICHIKHO) $143.10 USD
26555-H1902 ASSY-LAMP REAR COMBNATION LH (ICHIKHO)
26550-H7000 ASSY-LAMP REAR COMBINATION RH FROM 0772 $143.10 USD
26555-H7000 ASSY-LAMP REAR COMBINATION LH FROM 0772
26551-H1902 ASSY-LENS RH RED-RED-WHITE (ICHIKHO) $35.63 USD
26556-H1902 ASSY-LENS LH RED-RED-WHITE (ICHIKHO) $35.63 USD
26563-H1600 ASSY-HARNESS,R.H NLA
26564-H1600 ASSY-HARNESS,L.H NLA
* No 3W bulb
LENS same as #H10
RIM same as #H10
PACKING same as #H10
willieoec-img600x450-1327305935gofhdj11103.jpg willieoec-img600x450-1327305935q4txdf11103.jpg
LENS
84220576_480435049309234_680238105751453696_o.jpg.5f2f2c4c13e32e4cf7416c354a4b5dc3.jpg
H19
For worldwide market
YELLOW-RED-CLEAR
20738.jpgAlbum 20738 15056.jpgAlbum 15056
EverAce T-1756 & T-1757
27867.jpgAlbum 27867 27868.jpgAlbum 27868
27869.jpgAlbum 27869
Ever Wing T-1756, T-1757. Yellow indicator with 4-bulb housings
IKI 4004 R & 4004 L -- 1 E4 310 R-120 SAE ISTR 69 #markings
4004a.jpg 4004b.jpg 4004c.jpg 4004d.jpg 4004e.jpg 4004f.jpg 4004La.jpg 4004Lb.jpg 4004Lc.jpg 4004Ld.jpg 4004Le.jpg 4004Lf.jpg 4004Lg.jpg 4004Lh.jpg
LENS
20734.jpgAlbum 20734 20735.jpgAlbum 20735
lens with RIM fitted. The metal dividers are to prevent light bleed-through to the next section.
20706.jpgAlbum 20706
