Datsun 1200 used two types of Propeller Shaft:
- Replaceable U-joints
- Non-replaceable
If yours has snap rings (C-shaped circlips) holding the U-joints in, they are replaceable.
B10/B110/B210
- Nissan Part Number 37125-H1025, which replaced 37125-18025
- NLM NL-N28
- GMB GUN28
- Koyo N2057
- Toyo TN-128
- Matsuba UJ112
- Maxeen MN-28
- Beck/Arnley 102-0353
- ACDELCO Part # 45U0008 {#89029273} $16.16 USD from RockAuto.com
- NEAPCO 10028 $14.99 USD from PartsAmerica.com
- McQuay-Norris U1500
Type: Inside snap ring (grooves in cap for the snapring)
- (L) Diameter: 20.01 mm
- (O) Inside snap ring-to-ring: 35 mm
- ring-to-ring center: 38mm
Reportedly the same as 1981 - 1984 STARLET
B310
- Nissan Part Number37125-H8500
- Maxeen MN-45
- GMB GUN45
Type: Outside snap ring (grooves in yoke)
- (L) 20.07
- (N) Outside snap-ring, Length: 52.40
Non replaceable staked in u-joints Rockford Rockford Drive line has replacement u-joints available to replace the staked in u-joints used on some of the B210 and the B310 cars.
- Rockford 430-9
Inspection
Classic Symptoms:
- Vibration at high road speeds
- "Clunk" sound when backing up
Remove the Propeller Shaft from the diff (you can leave it in the transmission. flex the u-joints by hand. It should:
- Move smoothly (not stiff)
- Be tight
Replace if loose or binding.
Replacement Procedure
Use a press.
