Sunny Truck Distributors
Revision as of 06:51, 29 August 2009; view current revision
Late-model Electronic Distributor. For A12 in Sunny Truck. Made by Mitsubishi. Fitted by factory to Datsun 1200.
22100-95W10
  • 22100-95W10 DISTRIBUTOR ASSY A12S 8910- ミツビシ
  • 22100-95W12
  • 22020-G5111 TRANSISTOR IGNITION UNIT [fits inside distributor]
  • B2235-U7410 TAPE-SEAL, DISTRIBUTOR 7510- [a roll of tape]
  • 22301-95W10 CONTROL ASSY-VACUUM
  • 22023-G5110 UNIT-SETTER
  • 22201-22010 SCREW 7510- [fixing timing plate to distributor]
  • 22180-71200 SEAL-O RING [distributor to engine block]
  • 22101-95W10 HOUSING ASSY-DISTRIBUTOR
  • Condensor: None used
  •  ? 22107-95W10 GOVERNOR SET-DISTRIBUTOR
  • 22115-95W10 SIGNAL-ROTO ASSY
  • 22109-52H60 WEIGHT-GOVERNOR
  • 22127-95W10 SPRING-GOVERNOR
  • 22136-77A11 PLATE ASSY-BREAKER
  • 22132-95W10 CAM SET
  • 22229-95W10 SIGNAL SET
Cap & Rotor
  • 22162-78A10 CAP ASSY-DISTRIBUTOR
    • 22185-95W10 PACKING [seal, cap to body]
    •  ? 04136-00211 SCREW
  • 22157-23G15 ROTOR-HEAD
22100-G5110
  • 22100-G5110
Unknown
