Sunny Truck Wiring
Revision as of 07:10, 14 June 2010; view current revision
Categories: Sunny Truck | Body Electrical System | Engine Electrical System
  • 24012-95W00 HARNESS ASSY-ENGINE ROOM 8910-
  • 24013-95W00 HARNESS ASSY-INSTRUMENT 8910-
  • 24014-95W00 HARNESS ASSY-BODY 8910-
  • 24015-95W00 HARNESS ASSY-TAIL SB 8910-
  • 24015-95W01 HARNESS ASSY-TAIL LB 8910-
  • 24077-95W00 HARNESS ASSY-ENGINE ROOM SUB 8910-
  • 24160-G1001 HARNESS ASSY-ROOM LAMP all
  • 24022-01E01 LINK-FUSIBLE 8910-
  • 24310-95W00 BLOCK ASSY-FUSE 8910-
  • 24311-92W00 COVER-FUSE BOX 8910-
Instrument Panel
  • 25160-H1101 SWITCH ASSY-LIGHTING all
    • B5160-B6800 replaced the above $41.08 USD
  • 25230-C9970 RELAY NILES ENGINE CONTROL 8910-
  • 25230-C9980 RELAY MIYAMOTO ENGINE CONTROL 8910- $28.42 USD
    • a 4-pin relay with a blue plastic housing in either Niles brand (25230-C9970) or Miyamoto brand (25230-C9980). Either of the two brands is interchangeable
    • Used in many 1979-1997 Nissans
  • 26320-89905 RELAY ASSY-PASSING LIGHT $13.45 [also used for horn relay]
  • 25260-G1060 SWITCH ASSY-WIPER 8110-
    • also 7804-8109 w/INTMT WIPER
  • 28890-B8060 AMP-INTERMITTENT WIPER
  • 24428-89900 BATTERY TRAY
Engine Control
  • 22604-95W00 ENGINE CONTROL MODULE 8910-
  • 22690-F5300 HEATED OXYGEN SENSOR, REAR 8910-
Fuel
  • 22360-01M00 SWITCH ASSY-VACUUM 8910-
