Brake Pads
Revision as of 05:38, 10 June 2010; view current revision
Category: Brake System
Left: B110, Center: 1990-1994 B122, Right: JDM B310
Datsun 1200 (B110) uses Type D104 58 mm wide pad, while HB210 and HB310 use similar-looking but wider pads.
Pads: 63.5 mm (2.5 inch) vs 58 mm
B110/HB210/HB310
B110 Pad
Friction pad is 53.1 mm wide, backing plate is 58mm
NOTE: Aftermarket pads tend to be closer to 58mm
Type D104
41060-H1006 PAD ASS'Y-front disc brake B110 GL, GX, and all USA
Pad size:
* Width: 42.5 mm
* Thick: 10.3 mm
* Length: 53.1 mm
* Backing plate: 58 mm
Small Pad (58 mm for 212mm AN18 rotor)
Fits:
* 1971-1973 B110 USA
* B110 JDM GL, GX
* 1973-1974 Civic USA
* 1976-1978 F10 USA
* 1979-1982 N10 (Datsun 310) USA
* 1978-May 1979 PA10 Stanza GL, GLX
Raybestos PGD104
Wearever D41
Bendix D104
Beck/Arnley 0880100D?
ACDELCO 17D104 (18028686)
ACDELCO ACD39
ACDELCO ACD122
1974 HB210 Pad
Type D206
63.4 mm wide for 232 mm rotor (Annette 14/15 A)
Original spec is a larger pad than the HB310 unit
Pad specs:
* Width: 41.2 mm
* Thick: 10 mm
* Length: 63.4 mm
* Backing plate: 63.5 mm
* Material: D864P Nisshinbo
41060-S0100 KIT-PAD DISC BRAKE B210 USA -0475
41060-H7900 KIT-PAD DISC BRAKE B210 USA 0575-0775
41060-S0126 KIT-PAD DISC BRAKE B210 USA -0775
41060-H7926 KIT-PAD DISC BRAKE B210 USA -0775 $52.22 USD
Can use the HB310 pad (2.5 inch backing plate)
1974-1975 HB210 (A14 powered B210)
PB110 Sunny Excellent 1400
PB210 Sunny Excellent 1400 -1975.9
Skyline C10, C110, KC110 (1500, 1600) 1968-1975.9
Skyline 1800 PC10,KPC110,PC110 1968-1972.8
Laurel 1800 (C130K,C130) 1972.4-1973.9
Honda H1300
1976 HB210 Pad
61.4 mm wide for 245 mm rotor (Annette 14/15 AL)
41060-U6728 KIT-PAD DISC BRAKE B210 USA 0875- $45.02 USD
41060-U6725 KIT-PAD DISC BRAKE B210 USA 0875-
Pad specs:
* Width: 41.2 mm
* Thick: 10 mm
* Length: 61.4 mm
* Material: S21B Akebono
Material was change to S21B for improved durability at high temperatures and frictional resistance compared to D864P.
B310 Pad
Pad for AN-18 (220 mm rotor)
41060-H7825 PAD KIT-DISC BRAKE B310 CAN.A12 1278-
* Beck/Arnley 0820100 Premium Organic $9.18
fits:
* B310 A12A Canada (220mm AN18 rotor) [for 12" wheels]
Apparently the B110 pad (58mm) will fit.
HB310
2.5 inch backing plate width
41060-U6727 PAD KIT-DISC BRAKE A10 USA -0678 $86.98 USD
41060-U6728 PAD KIT-DISC BRAKE B310 USA $45.02 USD
D117 Pad
Type D117 for backing plate 63.5 mm
RockAuto for AN20 rotor
fits:
* 1974-1978 Datsun B-210 USA
* 1975-1979 Civic USA
* 1977-1979 Datsun 200SX (S10)
* 1979-1982 Datsun 210 (B310) USA
* 1975-1976 Datsun 610
* 1975-1977 Datsun 710
Raybestos SGD117/PGD117/RPD117
Beck/Arnley 0870944/0820944/0880944D
Wearever D103
Bendix D103
ACDELCO 17D117 (18028692)
D103 also D113. KD-29, MK D1008, AK A-33K
D146 Pad
Type D146
41060-U7426 PAD KIT-DISC BRAKE A10 USA 0778- $86.50 USD
* Superceeded by D106M-N2087
Look similar to the Sunny pads, but are not flat on the bottom.
Mystery
109.5
  • Rotor about 8"(203 mm).
108.5
108.5 x 40.3 mm
  • 108.5 mm total width x 40.3 mm x 14.7 mm thick
    • ~4.272" x 1.587" x 0.579" (inch)
    • 4-17/64
  • Apec 379
  • Interpart GBP666
    • CHERRY 1.0 1.3 1.3VAN 1.5 DE 09/82 A 08/86
    • CHERRY 1.5TURBO DE 09/82 A 05/84
    • CHERRY 1.6 DE 09/85 A 08/86
    • SUNNY 1.0 DE 06/86 A 10/88
    • SUNNY 1.3 DE 05/82 A 05/89 + 1.3 KOMBI DE 05/82 A 08/90
    • SUNNY 1.4 DE 10/88 A 12/90
    • SUNNY 1.5 DE 05/82 A 09/88 + 1.5 KOMBI DE 09/83 A 05/86
    • SUNNY 1.6 1.6COUPE DE 08/86 A 05/89
    • SUNNY 1.6I 1.6I COUPE DE 10/88 A 09/90
  • Lockheed/Delphi LP261
  • Bendix 552206/552208
  • Bosch 986469580
  • Ferodo FDB293
  • Lucas/TRW GDB288/GDB988
  • Quinton Hazell BP229
  • Nissan 41060-01A25,41060-01A85,41060-12A25,41060-13A25,41060-13A90,41060-25A25,41060-61A86,41060-62A90,41060-62A92,41060-67A90,41060-89A90,41060-89A91,DA060-13A85
  • Nissan 41060-77A91AS Pulsar, carb, 1984-1985 to -0485
    • Part number 41060-01A25 was superceded by part number 41060-77A91AS
  • Subaru 725191220 725191631 725191990 725193121
    • Justy 1984-2003 front
  • USA Nissan Pulsar 1984 2BBL carbureted
    • Nissan 41060 77 A91AS
  • WAGNER PD233/ZD233 or MX275, GUARDIAN 61233, MONROE DX275/CX275, AKEBONO ACT275, Brake Best MKD275, Raybestos RPD266M/RPD266/PGD233/RPD233, Centric 10002750, Beck/Arnley 0891243/0871243/0821243/0881243D/0881243M
    • 1983 Nissan Pulsar L4 1.6 Liter Carbureted - VIN P
    • 1983-1986 Nissan Pulsar NX 1.6 Liter Carbureted
    • 1987 Nissan Pulsar NX XE L4 1.6 Liter FI - VIN P (CA16DE)
    • 1988-1990 Nissan Pulsar NX
    • 1982-1990 Nissan Sentra
    • 1984-1985 Nissan Stanza
Friction Materials
  • FMSI 782-D41
  • FMSI 7059 (D41) Nissan, Honda
  • FMSI 7039 (D103) Nissan, Honda
    • 1976-1982 Cherry
    • 1980-1982 Pulsar
    • 1970-1974 1200
    • 1974-1976 B210
    • 1979-1981 Sunny
    • 1972-1979 Civic
    • 1969-1970 S800
  • FMSI 7040 (D104)
  • FMSI 7064-D113
Sunny Truck
Nissan 41060-G1985 PAD KIT-DISC BRAKE B120 8910-
Width: 108.4 mm
Height: 39.5 mm
Thick: 16.0 mm
Aftermarket:
Tokico TN289
Akebono AN-311
Kashiyama D1080-02
NiBK PN2306
Nisshinbo PF-2306
Sumitomo SN831
Tokico TN289 for B120 89/10-, box also says Akebono AN311, カシヤマ D1080-02
Akebono AN-31 1K (AN-311K) A311K
Labeled "Sunny Truck" and "89,10-" and "B12T,GB12T" [sic]
Nissan Competition
  • 41060-H1020 PAD ASSY-Brake FR DS11 AN18 caliper for Long distance driving
  • 41060-H1021 PAD ASSY-Brake FR M59S AN18 caliper for Short-medium distance driving
    Sumitomo M59S
