38300-H1000 ASSY-CARRIER WITH GEAR 39:10(3.900) 38310-G0400 COMP-CARRIER GEAR 38315-G0400 BOLT FIXING DIFF BEARING CAP 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP 38100-H1000 SET-GEAR & PINION HYPOID 39:10 38102-G0300 BOLT-DRIVE GEAR 38103-G0400 STRAP-LOCK BOLT 38421-G0500 CASE DIFFERENTIAL 38423-18000 GEAR-SIDE DIFF BEVEL 38424-18000 WASHER-THRUST SIDE GEAR 38424-18001 WASHER-THRUST SIDE GEAR 38424-18002 WASHER-THRUST SIDE GEAR 38425-18000 MATE-PINION DIFF BEVEL 38426-18000 WASHER-THRUST PINION MATE 38427-18000 SHAFT-PINION MATE 38428-G0400 PIN-LOCK DIFF PINION 38440-H1000 ASSY-BEARING DIFF SIDE 38440-18000 ASSY-BEARING DIFF SIDE 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50 38120-18000 ASSY-BEARING DRIVE PINION REAR 38140-18000 ASSY-BEARING DRIVE PINION FRONT 38165-H1000 SPACER-DRIVE PINION BEARING 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83 38189-18000 SEAL-OIL DRIVE PINION 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER 38210-18000 ASSY-FLANGE COMPANION 38215-01300 WASHER-PLASN 38216-18000 NUT-DRIVE PINION 38320-18010 GASKET-GEAR CARRIER 08915-13810 WASHER-LOCK 08911-20810 NUT
