Universal Joint
Revision as of 16:41, 6 February 2011; view current revision
Category: Propeller Shaft And Differential Carrier
Datsun 1200 used two types of Propeller Shaft:
  • Replaceable U-joints
  • Non-replaceable
If yours has snap rings (C-shaped circlips) holding the U-joints in, they are replaceable.
734.jpg standard u-joint
B10/B110/B210
  • Nissan Part Number 37125-H1025, which replaced 37125-18025
  • NLM NL-N28
  • GMB GUN28
  • Koyo N2057
  • Toyo TN-128
  • Matsuba UJ112
  • Maxeen MN-28
  • Beck/Arnley 102-0353
  • ACDELCO Part # 45U0008 {#89029273} $16.16 USD from RockAuto.com
  • NEAPCO 10028 $14.99 USD from PartsAmerica.com
  • McQuay-Norris U1500
Type: Inside snap ring (grooves in cap for the snapring)
  • (L) Diameter: 20.01 mm
  • (O) Inside snap ring-to-ring: 35 mm
    • ring-to-ring center: 38mm
Reportedly the same as 1981 - 1984 STARLET
B310
  • Nissan Part Number37125-H8500
  • Maxeen MN-45
  • GMB GUN45
Type: Outside snap ring (grooves in yoke)
  • (L) 20.07
  • (N) Outside snap-ring, Length: 52.40
Non replaceable staked in u-joints Rockford Rockford Drive line has replacement u-joints available to replace the staked in u-joints used on some of the B210 and the B310 cars.
  • Rockford 430-9
Inspection
Classic Symptoms:
  • Vibration at high road speeds
  • "Clunk" sound when backing up
Remove the Propeller Shaft from the diff (you can leave it in the transmission. flex the u-joints by hand. It should:
  • Move smoothly (not stiff)
  • Be tight
Replace if loose or binding.
Replacement Procedure
Use a press.
