Datsun 1200 uses traditional 8mm stem diameter poppet valves.
Stem Oil Seal
- BECK/ARNLEY Part # 0221446 [postive seal]
- umbrella seal
Retainers
Valve Spring Retainer Keeper (Valve lock)
- Stem diameter 0.252
- 7 degree angle
- SEALED POWER Part # VK215
- BECK/ARNLEY Part # 0230045
- Intake valve head diameter: 35 mm
- Exhaust valve head diameter: 29 mm
- Stem diameter: 8 mm
- Overall length: 103.80 mm
- Seat angle: 45 degrees
- Head style: standard
- Stem end: NG
- 13201-H1000 VALVE-INTAKE [35mm]
- 13202-18000 VALVE-EXHAUST [29mm]
- 13201-H2300 VALVE-INTAKE A12GX [35mm]
- 13202-H2300 VALVE-EXHAUST A12GX [29mm]
Valve Guides
•13212-H0112 GUIDE-VALVE INTAKE $8.08 •13213-H0113 GUIDE-VALVE EXHAUST $8.25
They have a little snap ring to limit the depth inserted in into the head
Others
For other A-series valves (A14, etc) and for competition valves, see: A-series_Cylinder_Heads#Valve_sizes
