Automatic Shifter
Revision as of 05:55, 14 November 2011; view current revision
Interior Shift Unit
Bushings
  • 34907-25820 BUSH-HAND LEVER BRACKET
    • B210: 34430-73001 BUSH-CROSS TUBE (2)
  • 34462-18000 BUSH-SPHERICAL CROSS SHAFT
    • B210: 34552-89900 INSULATOR
Raw Parts List
34902-H1900 ASSY-HAND LEVER & BRACKET
34903-H1900 ASSY-BRACKET HAND LEVER
34909-H1100 PACKING-HAND LEVER BRACKET
34915-H1100 ASSY-SUPPORT HAND LEVER
34946-H0300 SPRING-RETURN SELECT
34912-H1100 LEVER-HAND
34919-25820 KNOB-HAND LEVER
34919-H1000 KNOB-HAND LEVER
34923-25820 SCREW-HAND LEVER
34947-25820 PIN-SELECT
18136-61503 RING-SNAP"E"
34913-H1900 ASSY-SHAFT HAND LEVER
34434-89900 SCREW-LOCK
00851-21610 WIRE-LOCK
08360-82014 SCREW-MACHINE M8X1.25
34932-H2520 COMP-SHAFT ROD
34552-89900 INSULATOR-ROD
34419-04100 WASHER-SPRING
34485-14805 PIN-SPRING
34951-H2520 ASSY-CROSS SHAFT
34952-H1100 COMP-BRACKET CROSS SHAFT
34965-25820 COVER-OUTER RH CROSS SHAFT
34966-25820 COVER-INNER RH CROSS SHAFT
34463-14806 SPRING-RETURN CROSS SHAFT
34467-84700 BOOT-OUTER CROSS SHAFT
74941-89900 COVER-OUTER LH CROSS SHAFT
34936-H1100 COMP-SHAFT ROD LOWER
34938-25820 PIN-SHAFT ROD
34948-25820 RING-SNAP 'E' TYPE
34410-21000 TRUNION-GEAR SHAFT ROD
01311-00021 WASHER-PLAIN
08911-14010 NUT-HEX M10X1.25
Shift Linkage
Bushings
  • 34462-18000 BUSH-SPHERICAL CROSS SHAFT (2) B110,B210
  • 34552-89900 INSULATOR-ROD (4) B110,B210 [34410A, 34413B]
