Universal Joint
Revision as of 04:20, 29 November 2011; view current revision
Category: Propeller Shaft And Differential Carrier
Datsun 1200 used two types of Propeller Shaft, the type with replaceable U-joints, and the type that is not replaceable.
[hide]
Datsun 1200 used two types of Propeller Shaft:
  • Replaceable U-joints
  • Non-replaceable
Nissan calls the non-replaceable the "shell type", and the original the "solid type".
Japan-Market models, availability of Shell bearing type. The Solid type may have continued even after this.
  • Sedan from MAR 1973 Chassis # B110-767755-77572
  • Coupe from OCT 1972 Chassis # KB110-981519-999999, KB110-550001-552609
North America-Market models
  • Shell type from MAR 1973
If yours has snap rings (C-shaped circlips) on the inside holding the U-joints in, they are replaceable.
734.jpg standard u-joint
Replaceable
B10/B110 with replaceable joints
  • 37125-H1025 JOURNAL KIT-with bearing (Solid type) $84.93
    • replaced 37125-18025
    • 37146-18000 RING-snap, bearing race (1.46t)
    • 37147-18000 RING-snap, bearing race (1.48t)
    • 37148-18000 RING-snap, bearing race (1.50t)
    • 37149-18000 RING-snap, bearing race (1.52t)
  • NLM NL-N28
  • GMB GUN28
  • Koyo N2057
  • Toyo TN-128
  • Matsuba UJ112
  • Maxeen MN-28
  • Beck/Arnley 102-0353
  • ACDELCO Part # 45U0008 {#89029273} $16.16 USD from RockAuto.com
  • NEAPCO 10028 $14.99 USD from PartsAmerica.com
  • McQuay-Norris U1500
  • Rockford K1500
    • 0.788 inch Bearing diameter
    • 2.236 inch outside lock-up
    • Spicer 1000 Type
Type: Inside snap ring (grooves in cap for the snapring)
  • (L) Diameter: 20.01 mm
  • (O) Inside snap ring-to-ring: 35 mm
    • ring-to-ring center: 38mm
Reportedly the same as 1981 - 1984 STARLET
USA and Japan market models all use shell-type which are non-replaceable.
B310
  •  ??? Nissan Part Number 37125-H8500 ???
  • Maxeen MN-45
  • GMB GUN45
Type: Outside snap ring (grooves in yoke)
  • (L) 20.07
  • (N) Outside snap-ring, Length: 52.40
Non replaceable staked in u-joints
Rockford Drive Line has replacement u-joints available to replace the staked in u-joints used on some B110 shafts, and all B210 and B310 shafts.
Specialty "STAKED-IN" Universal Joints...
For over thirty years automakers have decreased assembly time and cut production cost by crimping universal joints into driveline assemblies. According to the manufacturer the joints are "STAKED-IN" and non-replaceable.
Rockford offers expanded replacement-joint coverage designed specifically for these varied applications.
  • Rockford 430-9
    • Fits:
    • 1971-1985 Datsun B120 Truck
    • 1971-1973 Datsun B110
    • 1974-1978 Datsun B210 (210)
    • 1979-1982 Datsun B310
    • 1989-1994 Subaru Justy
  • 0.791 inch Bearing diameter
  • 1.285 inch Inside Lockup [yoke inside width]
Inspection
Classic Symptoms:
  • Vibration at high road speeds
  • "Clunk" sound when backing up
Remove the Propeller Shaft from the diff (you can leave it in the transmission to prevent transmission fluid from leaking). Flex the u-joints by hand. It should:
  • Move smoothly (not stiff)
  • Be tight
Replace if loose or binding.
Replacement Procedure
Use a press.
