Sunny Truck Distributors
Revision as of 09:17, 17 June 2011; view current revision
Categories: Sunny Truck | Engine Electrical System
Sunny Truck was fitted with a regular (contact points) distributor through October 1989. From there on it was fitted with Electronic Ignition.
Versions
22100-H1001 DISTRIBUTOR ASS'Y (HITACHI D411-61)
* B110 Type
22100-G1400 DISTRIBUTOR ASS'Y (HITACHI D411-97) (from '73-4)
* B210 Type
22100-H1011 DISTRIBUTOR ASS'Y (MITSUBISHI TVG-4FL)
* alternate B110 type
22100-G1410 DISTRIBUTOR ASS'Y (MITSUBISHI TVT3T01877) (from '73-1)
* alternate B210 type
22100-G1610 DISTRIBUTOR ASSY 7510-7907
22100-W8511 DISTRIBUTOR ASSY 7907-8602
22100-G1910 DISTRIBUTOR ASSY 8602-8910
22100-95W10 DISTRIBUTOR ASSY 8910-
The last one is Electronic Ignition
Coils
All used with ballast resistor, except the Electronic Distributor
  • 22433-U3100 COIL ASSY-IGNITION [HITACHI] 7510-8910
  • 22433-U3110 COIL ASSY-IGNITION [HANSHIN] 7510-8910
  • 22433-U3140 COIL ASSY-IGNITION [MITSUBISHI] 8504-8910
  • 22433-52A60 COIL ASSY-IGNITION MITSUBISHI
Resistor
  • 22460-14606 RESISTOR-IGNITION COIL 7510-8910 Hitachi choice
    Hanshin HP5-13E10 12V-R(ヒタチ センタク シヨウ)
  • 22460-14615 RESISTOR-IGNITION COIL 7510-8910 Hanshin choice
  • 22460-14645 RESISTOR-IGNITION COIL 8504-8910 Mitsubishi choice
22100-W8511
22100-G1910
22100-95W10
This is fitted to Datsun 1200 trucks from October 1989 through end of production in 1994. It is a nice unit with the transistor unit mounted in the distributor body, under the distributor cap. Late-model Electronic Distributor.
Hitachi T4T66373
  • 22462-52A60 COIL-IGNITION
  • 22100-95W10 DISTRIBUTOR ASSY A12S 8910- ミツビシ (Mitsubishi) デストリビユーター (デストリビューター)
  • 22100-95W12
  • 22020-G5111 TRANSISTOR IGNITION UNIT [fits inside distributor]
  • B2235-U7410 TAPE-SEAL, DISTRIBUTOR [a roll of tape] 7510-, 1194- B14U SR20DE,GA16DE
    • superceded by 22235-U7400 $3.39 USD
  • 22301-95W10 CONTROL ASSY-VACUUM
  • 22023-G5110 UNIT-SETTER
  • 22201-22010 SCREW 7510- [fixing timing plate to distributor]
  • 22180-71200 SEAL-O RING [distributor to engine block] A/L/Z engines $4.25 USD
  • 22101-95W10 HOUSING ASSY-DISTRIBUTOR
  • Condensor: None used
  •  ? 22107-95W10 GOVERNOR SET-DISTRIBUTOR
  • 22115-95W10 SIGNAL-ROTO ASSY
  • 22109-52H60 WEIGHT-GOVERNOR
  • 22127-95W10 SPRING-GOVERNOR
  • 22136-77A11 PLATE ASSY-BREAKER
  • 22132-95W10 CAM SET
  • 22229-95W10 SIGNAL SET
Cap & Rotor
  • 22162-78A10 CAP ASSY-DISTRIBUTOR B12 1088- GA16I $27.36 USD
    • 22185-95W10 PACKING [seal, cap to body]
    •  ? 04136-00211 SCREW
  • 22157-23G15 ROTOR-HEAD $6.88 USD
Cap fits North America models:
  • 1988-1990 Nissan Sentra with Mitsubishi distributor
    • Oreillys.com E16 or GA16 Sentra
    • Master Pro C672
    • BWD C672
    • Beck/Arnley 1746918
    • Niehoff Ultra WA468A; Pro-Power WA468ACS
    • Bosch 03320
    • Standard Motor Products JH180
    • AC/Delco E338A
  • 1987-1988 Nissan Pulsar NX
Bosch 03320 CAP fits North America models:
  • Nissan 1983-1994
    • 1989-1990 Nissan 240SX
    • 1990-1994 Nissan Pickup
    • 1983-1990 Nissan Pulsar NX
    • 1991-1993 Nissan NX
    • 1984-1994 Nissan Sentra
  • Subaru 1987-1991
    • 1988-1989 Subaru DL
    • 1990-1994 Subaru Loyale
    • 1987-1989 Subaru GL
    • 1987-1989 Subaru RX
    • 1987-1989 Subaru GL-10
    • 1987-1991 Subaru XT
  • Suzuki
    • 1989-1994 Suzuki Swift
Mitsubishi T4T Family
Mitsubishi T4T series came with points and electronic versions. See Mitsubishi T4T Distributors.
