See:
The intake & exhaust share many parts
Also see Intake Manifold and Exhaust Manifold for photos and parts cross-references.
B110 RAW LIST 14003-H1900 MANIFOLD-INTAKE 14003-H1901 MANIFOLD-INTAKE 14003-H3900 MANIFOLD-INTAKE 14003-H3901 MANIFOLD-INTAKE 14003-H1000 MANIFOLD-INTAKE 08216-62210 STUD FIXING CARBURETOR 14004-H1930 MANIFOLD-EXHAUST 14004-H3931 MANIFOLD-EXHAUST 14004-H3950 MANIFOLD-EXHAUST 14004-H1030 MANIFOLD-EXHAUST 14004-H3930 MANIFOLD-EXHAUST 08213-82810 STUD FIXING EXHAUST MANIFOLD TO EXHAUST 14005-18001 GASKET-INTAKE TO EXHAUT MANIFOLD 14005-18000 GASKET-INTAKE TO EXHAUT MANIFOLD 08110-63210 BOLT INTAKE TO EXHAUT MANIFOLD 01111-00032 BOLT 08915-13610 WASHER-LOCK INTAKE TO EXHAUT MANIFOLD 08911-10810 NUT CYLINDER HEAD TO MANIFOLD 08915-13810 WASHER-LOCK 14037-32200 YOKE-MANIFOLD 14035-K7700 GASKET-MANIFOLD TO CYLINDER HEAD 14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD 14022-18000 SPRING-HEAT CONTROL THERMS 14025-85061 KEY-HEAT CONTROL VALVE 14026-18001 WEIGHT-COUNTER VALVE 14027-36700 WASHER-HEAT CONTROL 14047-36700 SPRING-STOPPER HEAT CONTROL 00933-1101A PLUG-WELCH 00933-11000 PLUG-WELCH 08310-51610 SCREW-SET 14006-18000 PIN-SPRING HEAT CONTROL TO INTAKE MANIF 16174-H1000 INSULATOR-CARBURETOR 16177-H1000 KIT-JOINT SEAT 16174-H3900 INSULATOR-CARBURETOR 16177-H3900 KIT-JOINT SEAT 08915-13610 WASHER-SPRING 08911-10610 NUT-HEX M6
