Brake Piping
Right Hand Drive (1) front drums (2) front discs
1 46223-H1001 TUBE ASS'Y-brake master cylinder to connector (up to '72-7) (Single M/C) 1 46223-H3200 TUBE ASS'Y-brake master cylinder to connector 1 46223-H3201 TUBE ASS'Y-brake master cylinder to connector (from '72-8) (Tandem M/C) 2 46234-H1000 CONNECTOR-brake tube (4-way)(up to '72-7)(Single M/C)
Disc Brakes, Left Hand Drive, Tandem Cylinder
1 46223-H1901 ASSY-TUBE BRAKE MASTER CYL. FR(TANDEM)TO 46223-H3900 ASSY-TUBE,B/MASTER CYL.FR (TANDEM) TO 46223-H3901 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 46223-G1300 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 46223-H1900 ASSY-TUBE BRAKE MASTER CYL FR(TANDEM)TO 46224-H3901 ASSY-TUBE,B/MASTER CYL. RR (TANDEM) TO 46224-H1900 ASSY-TUBE BRAKE MASTER CYL RR(TANDEM)TO 46224-H1901 ASSY-TUBE BRAKE MASTER CYL. RR(TANDEM)TO 46224-H3900 ASSY-TUBE,B/MASTER CYL.RR (TANDEM) TO 46100-26100 ASSY-SWITCH BRAKE INDICATOR 46100-U5200 ASSY-SWITCH BRAKE INDICATOR 08360-63514 SCREW-MACHINE WITH WASHER 46240-H1900 ASSY-TUBE BRAKE FRONT RH FOR TANDEM B 46240-H1901 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 46240-G1300 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 46242-H1900 ASSY-TUBE BRAKE FRONT LH FOR TANDEM B 46242-H1901 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 46242-G1300 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B 46280-H1905 ASSY-TUBE CONNECTOR TO REAR 46280-H1906 ASSY-TUBE CONNECTOR TO REAR 46280-H1901 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B 46313-18000 CONNECTOR-3WAY REAR 02463-13200 CONNECTOR-3WAY REAR 08110-82562 BOLT-HEX WITH WASHER M8 46290-H5501 ASSY-TUBE REAR BRAKE RH 46290-H7301 ASSY-TUBE REAR BRAKE RH 46290-H1000 ASSY-TUBE REAR BRAKE RH 46290-H1001 ASSY-TUBE REAR BRAKE RH 46290-H5001 ASSY-TUBE REAR BRAKE RH 46290-H7201 ASSY-TUBE REAR BRAKE RH 46310-H5501 ASSY-TUBE REAR BRAKE LH 46310-H5001 ASSY-TUBE REAR BRAKE LH 46310-H1000 ASSY-TUBE REAR BRAKE LH 46310-H1001 ASSY-TUBE REAR BRAKE LH 46201-89918 ASSY-HOSE BRAKE REAR L=330 46201-H7200 ASSY-HOSE BRAKE REAR L=330 46237-18000 GASKET-BRAKE HOSE TO TUBE 46205-61000 PLATE-LOCK BRAKE HOSE 46206-18000 SPRING-LOCK BRAKE HOSE
