Door Hinge
Revision as of 21:59, 18 May 2012; view current revision
Front door hinges are all the same: Sedan/Coupe/Ute/Wagon.
FRONT DOOR
Upper & Lower hinge differs
* Upper Left & Right hinge differ
* Lower is same on both sides
See Front Door Part Numbers
REAR DOOR
See Rear Door Part Numbers
Hinge Repair
Door dropping down on its hinges?
NAPA Door Hinge Pin & Bushing Kit
Pin Length: 2.85"
Pin Diameter: .313"
Bushing I.D.: 0.315"
Bushing O.D.: 0.397"
Motormite/Door Hinge Parts 38397
Tip: You may need to cut the pin to length
Usually the bushing is OK, but if you need them:
H0400-73002 BUSH-DOOR HINGE UPPER $2.53 USD
H0402-H1001 BUSH-DOOR HINGE LOWER $1.29 USD
Also see: Datsun Door hinge repair from NWDE
