Anti-sway bar
Revision as of 23:45, 24 December 2011; view current revision
Category: Suspension
The Anti-sway bar, also known as a swaybar helps bumps on left side of car from affecting right side of car and vice-versa. Nissan calls this the stabilizer.
Upgrade
B210 has a swaybar larger than B110.
See: B210 Swaybar Upgrade
  • 16mm (5/8")
  • B110: 17mm
  • B210: 18mm with A12 or A13
  • B210: 20mm with A14
  • 22mm (7/8")
  • 54617-H1001 BUSH-STABILIZER $3.35 USD
  • 56125-18100 BUSH-RUBBER SHOCK ABSORBER $3.18 USD
  • 54618-95W25 ASSY-ROD CONNECTING FRONT STABILIZER $23.72 USD
    • formerly 54618-H2300
Aftermarket
http://swaybars.com/index.asp?PageAction=VIEWCATS&Category=1300
  • Front: #877, 7/8" $168
  • Rear: #225, 5/8" $132
B310
B310 bar does not fit B110. It is about 3mm thicker than the 1200 bar. 955mm fixing hole centres.
