SAP
Revision as of 10:21, 16 December 2012; view current revision
Category: Suspension Modifications
This late 1200 lower control arm (LCA) bolts into and is compatible with older 1200s. Yet makes it easy to fit either small (45mm) or large (2.0 inch) struts.
Also see Strut swaps
What you will need to make them bolt straight in:
  • Strut Top and Upper Spring Perch for your car
    • (do not use the ones that came from the strut donor car)
  • Compatible Lower Control Arms (Late 1200 ute, Late 120Y)
  • Compatible Castor rods (Late 1200 Ute or Late 120Y)
  • Ball joints, Steering arms, Outer Tie rod Ends, Tie rods
click
Applied Model Code
H10 is B110 parts
H72 is B210 parts
H74 is late B210/late B120 ute parts
H85 is B310 1200 parts
W50 is A10 parts (also used by B310)
Also see: Strut Swaps
45mm Strut
To fit Datsun 45mm struts, use a 45mm strut-accepting package. Datsun B110, 120Y, and B310 12" wheel models already have this.
early 45mm strut support:
* H10 LCA with H10 Tension Rod
* H10 Balljoint
* H10 Knuckle Arm
* 45mm strut (B110, B120 or 120Y)
late 45mm strut support (will retrofit)
* H85 LCA with H72 Tension Rod
* H74 Balljoint
* H74 Knuckle Arm
This LCA allows use of 2.0" struts
Fits these struts, which bolt straight in to any 1200
  • 1200
  • early 120Y
2-inch Strut
To fit Datsun 2" struts, use 2" strut-accepting package (what you will need to make them bolt straight in)
2" strut support:
* W50 Balljoint
* W50 Knuckle Arm
* 2" Datsun Strut (280ZX, S13, 810, etc, but NOT S30 240Z/260Z/280Z)
* Strut Top and Upper Spring Perch (use standard ones for your Car)
Alternatively you can use LCA/Rod, balljoints and knuckle arms from other datsuns -- with or perhaps w/o modifications -- but it is more straightforward to use the factory Sunny parts. W50 is Datsun A10/B310 parts.
All except B310 and A10 will require moving the lower spring seat.
2.0" struts include:
  • B310 (Sunny/210, except A12-powered models)
  • Early A10 (Stanza/510)
  • Early Datsun 240K
  • Datsun 180B
  • Datsun 810/910
  • Datsun 280ZX
  • Skyline R31
  • Skyline R30
  • 910 Bluebird/Maxima/810
  • S12 Silvia/200SX
  • Z31 300ZX
These are not recommended:
  • 510/610/710 including 180B and 160J - camber angle is more positive than stock
  • S30 (240Z/260Z/280Z) - knuckle arm requires extra wide bolt pattern
For R31 type struts, you will also need a shear-load spacer ring (available from Datsport) which fits between the strut and the knuckle arm.
