Three Speed Transmission
Revision as of 02:04, 25 June 2007; view current revision
Category: Transmission
All Datsun 1200s were fitted with a 4-speed floor shift manual transmission (FS4W56). However, in most markets some Standard models had a 3-speed column shift (R3W56). This transmission had a higher 1st gear (3.380:1) than the 4-speed (3.757:1), meaning takeoff was a bit slower than the 4-speed, and starting on steep hils a bit more difficult. The 4-speed is a direct bolt-in replacement for the 3-speed.
See Transmission Overview for:
  • Maintainence specifications (oil type, capacity, etc)
  • Comparison of other B110 avaialble transmissions
  • Gear ratios
  • Link to the transmission swap article
Note that the United States market only got 4-speeds tranmissions.
