Brake Lines
Revision as of 04:55, 17 August 2013; view current revision
Category: Brake System
Brake Piping
Choices
  1. get pre-made lines of various lengths and bend and install it yourself
  2. get brake line material and fittings and cut it, flare it and fit it
  3. pay a shop to make and install custom lines
  4. buy genuine brake lines from Nissan and install. The ute parts are still available, and most will fit a Sedan or Coupe.
The first two are available at the usual spare auto parts stores, or mail order from hot rod stores.
Right Hand Drive (1) front drums (2) front discs
1 46223-H1001 TUBE ASS'Y-brake master cylinder to connector (up to '72-7) (Single M/C)
1 46223-H3200 TUBE ASS'Y-brake master cylinder to connector
1 46223-H3201 TUBE ASS'Y-brake master cylinder to connector (from '72-8) (Tandem M/C)
2 46234-H1000 CONNECTOR-brake tube (4-way)(up to '72-7)(Single M/C)
Disc Brakes, Left Hand Drive, Tandem Cylinder
46223-H1901	ASSY-TUBE BRAKE MASTER CYL. FR(TANDEM)TO
46223-H3900	ASSY-TUBE,B/MASTER CYL.FR (TANDEM) TO
46223-H3901	ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO
46223-G1300 	ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO
46223-H1900	ASSY-TUBE BRAKE MASTER CYL FR(TANDEM)TO
46224-H3901	ASSY-TUBE,B/MASTER CYL. RR (TANDEM) TO
46224-H1900	ASSY-TUBE BRAKE MASTER CYL RR(TANDEM)TO
46224-H1901	ASSY-TUBE BRAKE MASTER CYL. RR(TANDEM)TO
46224-H3900	ASSY-TUBE,B/MASTER CYL.RR (TANDEM) TO
46100-26100	ASSY-SWITCH BRAKE INDICATOR
46100-U5200	ASSY-SWITCH BRAKE INDICATOR
08360-63514	SCREW-MACHINE WITH WASHER
46240-H1900	ASSY-TUBE BRAKE FRONT RH FOR TANDEM B
46240-H1901	ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE
46240-G1300 	ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE
46242-H1900	ASSY-TUBE BRAKE FRONT LH FOR TANDEM B
46242-H1901	ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE
46242-G1300	ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE
46280-H1902	ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B
46280-H1905	ASSY-TUBE CONNECTOR TO REAR
46280-H1906	ASSY-TUBE CONNECTOR TO REAR
46280-H1901	ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B
46313-18000	CONNECTOR-3WAY REAR
02463-13200	CONNECTOR-3WAY REAR
08110-82562	BOLT-HEX WITH WASHER M8
46290-H5501	ASSY-TUBE REAR BRAKE RH
46290-H7301	ASSY-TUBE REAR BRAKE RH
46290-H1000	ASSY-TUBE REAR BRAKE RH
46290-H1001	ASSY-TUBE REAR BRAKE RH
46290-H5001	ASSY-TUBE REAR BRAKE RH
46290-H7201	ASSY-TUBE REAR BRAKE RH
46310-H5501	ASSY-TUBE REAR BRAKE LH
46310-H5001	ASSY-TUBE REAR BRAKE LH
46310-H1000	ASSY-TUBE REAR BRAKE LH
46310-H1001	ASSY-TUBE REAR BRAKE LH
46201-89918	ASSY-HOSE BRAKE REAR L=330
46201-H7200	ASSY-HOSE BRAKE REAR L=330
46237-18000	GASKET-BRAKE HOSE TO TUBE
46205-61000	PLATE-LOCK BRAKE HOSE
46206-18000	SPRING-LOCK BRAKE HOSE
