Vacuum hoses on the 1200 follow a simple layout.
1. VACUUM ADVANCE
Vacuum Advance
The A12 will run good with the vacuum advance disconnected, but will run smoother and get better fuel economy with it working.
Connect a hose from the distributor to the port connection directly above the idle mixture screw.
Vacuum advance in all models uses a hose from the 'port' on the carburetor to the Distributor.
For more information, see Vacuum Advance
= Carbon Canister
For late model 1200s, Tee into this line and connect a hose to the Charcoal Canister "VC" line. The canister is for the Fuel Tank vent. Since these fuel tanks are sealed, it needs to vent somewhere.
just three connections: 1. Fuel tank vent line (connection by itself) 2. PURGE - to intake manifold (bottom connector) 3. Vacuum Control (top connector) - to vacuum advance hose
USA models have more emission controls, so a couple extra lines are used.
See:
- Emission Controls#Throttle Opener
- Emission Controls#Temperature Controlled Air Cleaner
- Fume Control (for the Flow Guide Valve details)
- TCVAS
