1/4 mile time log
Revision as of 14:33, 5 August 2007; view current revision
Categories: General Information | Racing | User Community
Here is a list of 1/4 miles times from the varied list of Datsuns in our club. (Main Source)
A12
Fat_120y
  • 60 foot time:2.428
  • 1/4 mile time:16.093
  • MPH/KPH:89.4mph
  • CAR:120y 2dr sedan
  • MOTOR:1200
  • GEAR BOX:standard 4 spd
  • CLUTCH:exedy HD organic
  • DIFF:standard pull out centre
  • TURBO/SUPER CHARGER/CARBY:32/36 weber, with td04l baby turbo 10psi
  • EXHAST:3"
  • WHEEL/TYRE package:12" 165/65/12
boofhead
  • 60 foot time: 2.593
  • 1/4 mile time: 17.623
  • MPH/KPH: 78.07mph
Calder Park, Victoria, 25/03/2006
  • CAR: 1973 1200 sedan
  • MOTOR: A12 GX'ish mock up
  • GEAR BOX: 60a 5spd
  • CLUTCH: excedy organic
  • DIFF: stock h145
  • TURBO/SUPER CHARGER/CARBY: twin 40mm webers
  • EXHAST: 4-1 extractors, 2" system, single muffler
  • WHEEL/TYRE package: 15x6" skyline ti alloys, 195/50/15 street tyres
grall3
  • 60 foot time:
  • 1/4 mile time: 17.8
  • MPH/KPH: 140KPH
  • CAR: 120y 4 Door Sedan
  • MOTOR: A12 Worked
  • GEAR BOX: Standard
  • CLUTCH: Heavy Duty
  • DIFF: Austraian Borg
  • TURBO/SUPER CHARGER/CARBY: Twin Webbers 40DCOE
  • EXHAST: Extractors & 2" Pipe
  • WHEEL/TYRE package: Standard Road Tires 14"
littledarkone
  • 60 foot time: 2.592
  • 1/4 mile time: 19.316
  • MPH: 68.80
  • Car: 75' 120y 4 Door Sedan
  • Motor: A12 Standard
  • Gearbox: 56A 4 sp
  • Clutch: Standard
  • Turbo/Super Carger/ Carby: 32\36 DGV
  • Exhaust: A15 manifold with 1 3\4 inch pipe into lukey semi baffled dumped at diff
  • Wheel/ Tyre package: 175\70 R13 Front 155\something or rather 12 Rear
  • 60 foot time: 2.641
  • 1/4 mile time: 19.887
  • MPH: 65.18 mph
  • Car: Stock 1972 1200 (USA trim), but with electronic ignition
  • Gearbox: 56A 4 sp
  • Clutch: Standard
  • Turbo/Super Carger/ Carby: Standard hitachi
  • Exhaust: Stock
  • Wheel/ Tyre package:shorter-than-stock tires, wider tires (165/55-R12)
  • 80 lbs extra weight (toolbox, etc.) Maybe 2 gallons gasoline in tank
frankthedolphintrainer
  • 60 foot time: 2.707
  • 1/4 mile time: 20.42sec
  • MPH/KPH: 62.84mph
  • CAR: Datsun 1200 ute
  • MOTOR: A12
  • GEAR BOX: stock 4 speed
  • CLUTCH: stock
  • DIFF: stock
  • EXHAUST:2inch into mercury muffler and hi tech extractors
  • WHEEL/TYRE package: 15x195x45 nankangs
Burke_a_lot
  • 60 foot time:
  • 1/4 mile time: 23.0
  • MPH/KPH:
  • CAR: datsun 120y coupe
  • MOTOR: A12
  • GEAR BOX: stock
  • CLUTCH: stock
  • DIFF: stock
  • TURBO/SUPER CHARGER/CARBY: home made turbonator, force fuel injection
  • EXHAST: none
  • WHEEL/TYRE package: 12"
A14
finn
  • 60 foot time:1.88
  • 1/4 mile time:12.1
  • KPH:187
  • CAR:Datsun 1200 coupe
  • MOTOR:A14
  • GEAR BOX:Ford type 9
  • CLUTCH:190mm
  • DIFF:Escort rs2000
  • TURBO/SUPER CHARGER/CARBY:Turbo garret kkk k25, megasquirt injection, 2bar boost
  • EXHAST:3"
  • WHEEL/TYRE package:R14-205 street slicks(dot)
minnesh
  • 60 foot time:
  • 1/4 mile time:13.8
  • KPH:
  • Car :Sedan Datsun 1200
  • Motor: a14
  • Gearbox : Toyota 3t
  • Clutch : copper
  • Diff : Alfa LS
  • Carbs : 40 Webbers
  • Exhaust : 55mm
  • Wheels : 13" cosmo with semis
HYP014
  • 60 FOOT TIME : 2.0
  • 1/4 MILE TIME : 14.1
  • MPH: 97.1
  • CAR: 1200 coupe
  • MOTOR: A14
  • GEARBOX: option1 5speed
  • CLUTCH: exeedy ceramic button
  • DIFF: h165 locked 3.9:1
  • INDUCTION: 45mm throttle bodys
  • EXHAST: JTS extractors, 2.5" pipe
  • WHEEL/TYRE: 195,50,15 yokohama advans
sparkyZA
  • 60foot time:
  • 1/4mile time:15.63
  • mph/kph:136.4kph
  • CAR:1200 gx 4 door
  • MOTOR:A14
  • CARB:Twin 40 webers
  • GEARBOX:4speed std.
  • CLUTCH:custom
  • DIFF:alfa ls
  • EXHAUST:2.25"
  • WHEEL/TYRE package:front 155/80/12 rear 185/60/14(semi slicks)
  • 1/4MILE TIME 18.59(Wet Track)
  • CAR:Nissan Bakkie
  • Motor:A14
  • GEARBOX:Std 5 speed
  • CLUCTH:Stock
  • DIFF:Stock
  • CARBY:38 weber
  • EXT:5oMM
  • TIRE/WHEEL package:155/80/12
  • STD Steel Rims
littledarkone
  • 60ft time : 2.881
  • 1\4 mile : 19.545s
  • MPH/KPH: 68.18mph
  • car :Datsun 120y Sdan
  • motor : A14
  • gearbox : 60A 4 sp
  • Clutch : stock
  • Diff : H150 open
  • Carby : 32\36 Weber
  • Exhaust : 1 3\4 inch from standard A14\15 cast iron manifold
  • Wheels\Tyres : 13x6 Hustlers with 185\60 R13 Toyo Proxie RA1's
A15
datsonovic
  • 60 FOOT: ?
  • 1/4 MILE: 12.7 SEC
  • MPH/KPH: 102 MPH?
  • CAR: VB10 1000 wagon
  • MOTOR: A15
  • GEARBOX: FORD 4 SPEED
  • CLUTCH: SOLID SAW BLADE PLATE DUEL DIAPHRAM
  • DIFF: 3.89:1 120y BW LOCKED
  • TURBO: GARRET TO3 (HIGH FLOW BASED ON RB30)
  • EXHAUST: 2.5 INCH DUMPED AT DIFF
  • WHEEL/TYRE: 13/7 REBELS 205/65
sticks
  • 60 FT: 2.2
  • 1/4 MILE TIME 14.4
  • MPH 93
  • CAR: 1200 ute
  • MOTOR: A 15
  • G/BOX: 60 series 4 speed
  • CLUTCH: L series
  • DIFF: H 165
  • INDUCTION: 2x45 DCOE Weber
  • EXH: extractors 2" system
  • WHEEL?TYRE: 13x4.5 Sunny rims 165 kumho,s
A14force
  • 60 foot time:2.275
  • 1/4 mile time:14.539
  • MPH/KPH:92.539mph
  • CAR: 1200 sedan
  • MOTOR:A15
  • GEAR BOX:63A five speed
  • CLUTCH: heavy duty 200mm L series
  • DIFF: 3.9:1 H165 spring loaded locker
  • TURBO/SUPER CHARGER/CARBY: S/C14 weber 32/36
  • EXHAST: 2" with two resonators only
  • WHEEL/TYRE package:205/60/13 (Cheap nasty ones)
3Rotor
  • 60 foot:
  • 1/4 mile:14.7
  • MPH: 100.8mph
  • CAR: Nissan 1400 Ute
  • MOTOR: A15 (Langley Pistons)
  • GEAR BOX: W58 (Supra) was std 4spd
  • CLUTCH: 4 puk button, std flywheel\P-Plate.
  • DIFF: Std.
  • TURBO: GT1749.
  • INTERCOOLER: Yes, custom.
  • EXHAUST: 2.5 SS, one box.
  • WHEEL/TYRE Front: 195/50/14 Michelin.
  • WHEEL/TYRE Rear: 175/80/14 Goodyear.
SOURCE: G-Tech. DATE: 31mar07 11:54:00 aprox.
Grunterhunter
  • 60foot time: 2.1
  • 1/4mile time:14.72
  • mph/kph:144 kph
  • CAR:1200 ute
  • MOTOR: A15 (104rwhp @ 4800rpm)
  • CARB: 32/36 weber
  • SUPERCHARGER: Toyoya SC14 Rootes Blower, 10psi
  • CLUTCH: sunny
  • DIFF: H165 4.11
  • EXHAUST:2.5"
  • WHEEL/TYRE package:front 185/60/14 rear 185/60/14
Grunterhunter
  • 60 foot time: 2.3
  • 1/4 mile time: 16.9
  • MPH/KPH: 76mph (into 8kt headwind)
  • CAR: 1200 ute
  • MOTOR: A15, mild cam (54rwkw)
  • GEAR BOX: 5 speed
  • CLUTCH: stocka
  • DIFF: 4.11
  • TURBO/SUPER CHARGER/CARBY: 32/36 DGV weber
  • EXHAST: Extractors into a straight through 2.5"
  • WHEEL/TYRE package: 185/60R14
datsa73
  • 60 foot time: I'll have to check
  • 1/4 mile time: 17 sec
  • MPH/KPH: Speedo's gauge is off
  • CAR: 1973 2 Door Sedan
  • MOTOR: A15 Bored-Balanced-Port Polished- Redline at 9K
  • GEAR BOX: B210 5 Speed
  • CLUTCH: Standard
  • DIFF: 1200
  • TURBO/SUPER CHARGER/CARBY: Dual 32/36 Downdrafts
  • EXHAST: 2 1/2" with Glasspak
  • WHEEL/TYRE package: 15" 280z wheels
L20B
sticks
  • 60FT: 1.85
  • 1/4 MILE: 13.1 @ 100mph
  • CAR: 1200 sedan
  • MOTOR: L20b
  • GEARBOX: 1600 datsun
  • CLUTCH: upgraded L20b
  • DIFF: H165
  • INDUCTION: 2x45 DCOE weber
  • EXHAUST: extractors 2.5 system
  • WHEEL/TYRE: 13x6 steel 185 advan's (second hand)
sikdatto1200
  • 60 foot time: 2.1
  • 1/4 mile time: 16.7
  • MPH/KPH: 79mph
  • CAR:Datsun 1200 sedan
  • MOTOR:Standard L20b with ported head,(engines compression not healthy)
  • GEARBOX:280zx 5spd
  • CLUTCH:Standard 280xz
  • DIFF:Borgwarner 3.9, locked
  • TURBO/SUPER CHARGER/CARBY:38adm webber and adapter on standard manifold
  • EXHAUST:2 inch, standard manifold
  • WHEEL/TYRE PACKAGE:14inch et turbo rims on the front, 13inch 175 rears
CA18DET
jonboy
  • 60 foot time:1.64
  • 1/4 mile time:11.54
  • MPH/KPH:118mph
  • CAR:1200 ute
  • MOTOR:standard internal ca18det
  • GEAR BOX:r30
  • CLUTCH:extreme
  • DIFF:r31 4.11
  • TURBO/SUPER CHARGER/CARBY:gt25 75hp nos
  • EXHAST:3inch
  • WHEEL/TYRE package:m@h 26x6 slicks
ca18det_man
  • 60 foot time: 1.74
  • 1/4 mile time: 12.0
  • MPH/KPH:113mph
This 1/4 mile time was around 7 years ago when I first built it. It was regoed and fully legal driven too and from the track (old eastern creek wed night street meet)
  • CAR: 1200 coupe
  • MOTOR:Ca18det
  • GEAR BOX: MR30 skyline (stumpy)
  • CLUTCH:Daiken brass button sprung center
  • DIFF:Mitsibishi scorpoin 4.6:1
  • TURBO: GT25 290hp model
  • EXHAST:3" to diff then 2.5"
  • WHEEL/TYRE package: 14x6 with 205/60/14 hankooks
12OOU
  • 60 foot time: 1.71
  • 1/4 mile time: 12.4
  • MPH/KPH: 116mph
  • CAR: Datto 1200 Ute
  • MOTOR: CA18DET
  • GEAR BOX: CA18 5 speed
  • CLUTCH: 3400lbs 5 puk button
  • DIFF: r31
  • TURBO/SUPER CHARGER/CARBY: to4e
  • EXHAST: 3"
  • WHEEL/TYRE package: 225/50 toyo proxies
LAGWAGON
  • 60 foot time:
  • 1/4 mile time: 12.6
  • MPH/KPH: 108mph
  • CAR: Datsun 1200 Wagon
  • MOTOR: CA18 det
  • CLUTCH: Extreme cushion button
  • DIFF: Hilux with 30 spline axles
  • TURBO/SUPER CHARGER/CARBY: S15bb factory jap spec
  • EXHAST: 3 inch dump only
  • WHEEL/TYRE package: 13in x 8in M/T drag slicks
matty
  • 60 foot time: 1.815
  • 1/4 mile time: 12.753
  • MPH/KPH: 109.04mph
  • CAR: 1200 Ute
  • MOTOR: CA18DET
  • GEAR BOX: CA18DET 5 speed
  • CLUTCH: Jim Berry 2125lbs
  • DIFF: r31 LSD
  • TURBO/SUPER CHARGER/CARBY: GTi-R T28
  • EXHAUST: 3"
  • WHEEL/TYRE package: 195/60R14 Azenis
short-coupe
  • 60 foot time: 2.111
  • 1/4 mile time: 12.835
  • MPH/KPH: 109.14mph (175.65)
  • CAR: 1200 coupe
  • MOTOR: ca18det
  • GEAR BOX: s13 5sp.
  • CLUTCH: 5puck
  • DIFF: r31 4.11 lsd
  • TURBO/SUPER CHARGER/CARBY: t25g
  • EXHAST: 3"
  • WHEEL/TYRE package: 205/50/15" s-drive yoko's
Joshh
  • 60 foot time:2.460
  • 1/4 mile time: 13.5
  • MPH/KPH: 171.25 KPH
  • CAR: 1200 Ute
  • MOTOR: ca18det
  • GEAR BOX: 5 speed
  • DIFF: Skyline LSD
  • TURBO/SUPER CHARGER/CARBY:T28
  • WHEEL/TYRE package: 15" 50 by 195s
kegs
  • 60 foot time:
  • 1/4 mile time:13.6
  • MPH/KPH:106mph
  • CAR:1200 ute
  • MOTOR:ca18debt haha debt
  • GEAR BOX:mr30 stumpy
  • CLUTCH:exedy
  • DIFF:8 3/4 inch skyline r31
  • TURBO/SUPER CHARGER/CARBY:t25
  • EXHAST:3 inch
  • WHEEL/TYRE package:stockies
oan878
  • 60 foot time: 1.918
  • 1/4 mile time: 13.626
  • MPH/KPH: 95.85/154.25
  • CAR: Datsun 1200 sedan 4 dr
  • MOTOR: CA18 det
  • GEAR BOX: CA20 5 speed
  • CLUTCH: excedy soild centre brass button
  • DIFF: locked h165
  • TURBO/SUPER CHARGER/CARBY: stock turbo
  • WHEEL/TYRE package: 15in 215/60 toyo proxies
phat_dat1200
  • 60 foot time:1.8
  • MPH/KPH:95mph
  • CAR:1200 ute
  • GEAR BOX:s13
  • CLUTCH:hd organic
  • DIFF:r31 3.9
  • TURBO/SUPER CHARGER/CARBY:stock on 13psi
  • EXHAST:3inch
  • WHEEL/TYRE package: 13/205/60 toyo proxes ra1's
FRKYCA
  • 60 foot time:
  • 1/4 mile time: 13.9
  • MPH/KPH:
  • CAR: 1200 sedan 71
  • MOTOR: ca18det
  • GEAR BOX: 3 speed auto
  • CLUTCH:
  • COMPUTER: standed
  • DIFF: ute 1200 diff
  • TURBO/SUPER CHARGER/CARBY: t25 standed
  • EXHAST: 2.5"
  • WHEEL/TYRE package: standed 14"bluebird (white walled )
mcgee
  • 60FT: 2.071
  • 1/4MILE: 14.36
  • MPH/KPH 94.8MPH
  • CAR: 1200 coupe
  • MOTOR: CA18DET
  • G/BOX: manual CA18
  • DIFF: Mitsubishi 3.9 LSD
  • TURBO: garret GT2540R (10psi)
  • EXHAUST: 3"
  • WHEEL/TYRE: 195/60R14
dattodude
  • 60 FOOT TIME : dunno
  • 1/4 MILE TIME : 15.0
  • MPH: 91mph
  • CAR: 1200 sedan (my old car)
  • MOTOR: CA18det (<100psi in one cylinder) 78kW@wheels
  • GEARBOX: Stumpy Skyline 5 speed (crunched every gear change)
  • CLUTCH: whatever
  • DIFF: h165 3.9:1
  • INDUCTION: EFI, S14 T28
  • EXHAUST: 2.25 mandrel.
  • WHEEL/TYRE: 205/14-60
SR20DET
sticks
  • 60FT: 1.42-slick, 1.39-radial
  • 1/2 track: 113mph 112mph
  • 1/4MILE: 9.70 @ 137.07 slick, 9.79 @ 135.98 radial
  • CAR: 1200 wagon
  • MOTOR: sr20det
  • G/BOX: trimatic (transbrake) 5200 convertor
  • DIFF: hilux 3.7ratio
  • TURBO: garret gt30/40 (30 psi pump fuel) nos
  • EXHAUST: 3" with plumbed back gate pipe
  • WHEEL/TYRE: mt drag, 26-8.5-15 8' cragar star
mt drag radial, 235-50-15 7" ford pursuit rim
1200post
  • 60 Foota: 1.467
  • 1/4 mile: 11.012
  • MPH/KPH:121.50/195.53
  • Car:Datsun 1200 post 2 door sedan
  • Motor:SR20de stock
  • Gearbox: series 3 bluebird
  • Cluch: PBR standard
  • Diff: Galint
  • Turbo:T03 of a Z18t
  • Exhast: 2 1/2 mandrel bent mild steel
Built By: Myself and my very understanding girlfriend
Evey
  • 60 foot time: 2.2
  • 1/4 mile time: 12.9
  • MPH/KPH: 116mph
  • CAR: Datsun 1200 Ute (MIN712)
  • MOTOR: SR20DET
  • GEAR BOX: 5 SPD SR
  • CLUTCH: Extreme Button
  • DIFF: H165
  • TURBO/SUPER CHARGER/CARBY: T28 Plain B
  • EXHAST: 3 inch mandrel
  • WHEEL/TYRE package:205.40.16Falken Ziex street tyres
Z18T
trb012
  • 60ft time:2.137
  • 1/4 mile:14.56
  • MPH:94.81
  • CAR:120 y sedan
  • MOTOR:Z18 turbo
  • GEARBOX:Z18 5 speed
  • DIFF:VN borg warner 4.11 lsd
  • INDUCTION:Gas research 450cmf carby
  • TURBO:t3/t4 hiflow
  • EXHAUST:2-1/2 inch mandrel
  • WHEELS/TYRES:15/7 superlites with goodyear 195/55/15 f1's
SR20DE
twincharged
  • 1/4 mile time: 14.65
  • MPH/KPH: 93.10 mile
  • CAR: Datsun 1200 coupe
  • MOTOR: SR20DE STANDED Staight out of the half cut
  • GEAR BOX: Standed siliva 5 speed
  • CLUTCH: Det clutch
  • DIFF: 4.3 lsd 120y diff
  • TURBO/SUPER CHARGER/CARBY: EFI N/A
  • EXHAST: 2.5 inch
  • WHEEL/TYRE package: 195x15x6.5 es100
Other 4 cylinder
JVML
  • 60 foot time:1.276
  • 1/4 mile time: 9.8s
  • MPH/KPH: 132mph/211.2kph
  • CAR: Datsun B110
  • MOTOR: 4AG Turbo...Dyno 460HP at wheel
  • ECU: Microtech
  • Turbo Boost: 45psig, at 3rd Gear, RPM 12,128
  • Injector:750cc
  • GEAR BOX: 2JZ Toyota Supra
  • FLYWHEEL: 3.6Kg JAM
  • CLUTCH: 6 points HKS
  • DIFF: 4.3 AE86 LSD Full Time
  • TURBO/SUPER CHARGER/CARBY: Garrett TO4E
  • EXHAST: 3"
  • WHEEL/TYRE package: 215x15x65 Fully Slick Hoosier
AOO00A
  • 60 foot time: 2.227
  • 1/4 mile time: 14.803
  • MPH/KPH: 92.40mph (148.71kph)
  • CAR: 1200 ute
  • MOTOR: 4AGZE
  • GEAR BOX: Toyota Sprinter
  • CLUTCH: Made
  • DIFF: LC Lancer open centre
  • TURBO/SUPER CHARGER/CARBY:Supercharger STD 4AGZE
  • EXHAST: 2.5"
  • WHEEL/TYRE package: 205/50/15" Falken Rear
Tyrie
  • 60foot time:
  • 1/4mile time:15.4
  • mph/kph:140.0kph
  • CAR:120Y sedan 1060kg
  • MOTOR:4agze
  • CARB: no
  • GEARBOX: T50 5speed
  • CLUTCH: Excedy 4puck with very little clamping pressure :(
  • DIFF:R31 3.9 LSD
  • EXHAUST:2.5" with one muffler
  • WHEEL/TYRE package:front 195/50R15 rear 7x22x13 AVON formula ford tyres (rooted)
Only a Gtech run as we arent privilaged enough to have a track here.
Rotary 12A
ANGE
  • 60 foot time: 2.2
  • 1/4 mile time: 15.5
  • MPH/KPH: 85mph
  • MOTOR: 12a rotary (standard)
  • GEAR BOX: Ser4 Rx7 5spd
  • CLUTCH: standard
  • DIFF: 4.3 lsd
  • TURBO/SUPER CHARGER/CARBY: nikki 4brl
  • EXHAST: 2.25"
  • WHEEL/TYRE package: 15x6 195/55 semi slick
V8
dat383
  • 60ft time:1.3
  • 1/4 mile:9.89
  • mph:133.5mph
  • CAR:1200 sedan
  • MOTOR:383 small block chev
  • GEARBOX:powerglide
  • DIFF:9 inch spool
  • INDUCTION:aspirated,1050 methanol carby
  • EXHAUST:custom,3 inch,gonzo mufflers.
  • WHEELS/TYRES:15x10 &15x3 weld pro stars.26x10inch slicks.
Electric
EVdude
July 14, 2007
  • 60 foot time: 1.691
  • 1/4 mile time: 11.466 seconds
  • MPH/KPH: 114.08 mph
  • CAR: '72 Datsun 1200 sedan
  • MOTOR: Twin 8-inch in line
  • GEAR BOX: none, direct drive
  • CLUTCH: none
  • DIFF: Ford 9 inch w/Detroit Locker & 31 spline axles
  • TURBO/SUPER CHARGER/CARBY: none
  • EXHUAST: none
  • WHEEL/TYRE package: front 13 x 5.5 with 175/60 Nitto rear 14 x 6 with 215/60/14 BF Goodrich G Force drag radials
