Racing Suspension System
Revision as of 23:45, 10 November 2015; view current revision
Categories: Rear Axle And Rear Suspension | Nismo
From the 1984 Nissan Competition Catalog, Suspension section
1200 Front SPRINGS (114 LBS/IN)
B210 Front SPRINGS (80  LBS/IN) progressive rate
1200 STRUTS 45mm
B210 STRUTS 2"
1200 REAR BUMP STOP (Height = 50mm)
B210 REAR BUMP STOP (Height = 92mm)
th_Competition198446.jpg1200 COUPE RACING SUSPENSION SYSTEM
This factory racing suspension is an excellent kit for slalom, solo and regional competition. The struts are gas filled and have an adjustable lower spring perch. Depending upon the model year this kit will lower the 1200 coupe approximately 2". The component in this system must be used as a set.
PART NO.    DESCRIPTION        QTY. REQ.
45010-H1070 SPRING FRONT (112 LBS/IN) 2
54302-H1072 STRUT/RF                  1
54303-H1072 STRUT/LF                  1
55020-H1023 SPRING/REAR (140 LBS/IN)  2
55240-H1824 BUMP STOP/REAR (H = 50MM) 2
56210-H1823 SHOCK ABSORBER/REAR       2
th_Competition198446.jpgB210 COUPE RACING SUSPENSION SYSTEM
This factory racing suspension is an excellent kit for slalom, solo and regional competition. The struts are gas filled and have an adjustable lower spring perch. Depending upon the model year this kit will lower the B210 coupe approximately 2". The component in this system must be used as a set.
Same description as the 1200 system, except the front springs are progressive rate type.
45010-H5020 SPRING FRONT (80 LBS/IN)  2
54302-H5020 STRUT/RF                  1
54303-H5020 STRUT/LF                  1
55020-H5020 SPRING/REAR (140 LBS/IN)  2
55240-H5020 BUMP STOP/REAR (H = 92MM) 2
56210-H5020 SHOCK ABSORBER/REAR       2
