Carpet Cleaning Machine
Revision as of 05:52, 18 January 2016; view current revision
Category: A-series Engines
Prochem Performer 405 truckmount
http://www.youtube.com/watch?v=jdyLKlyDV30
A15 engine
carbureted
65 hp
OR A12 Industrial Nissan Engine 32hp
A15
governer $1009
2002 PowerVac II (48hp)
2002 Performer (48hp)
2002 Performer 405 (48hp)
Everest truckmount
A15
Zenith EFI fuel injection (ZEEMS)
Zenith Power Products
http://zenithpp.com/engines_a15.htm
Intermittent output (SAE Gross J1349) 46 HP/3,600 rpm
Continuous output (SAE Gross J1349) 39 HP/3,600 rpm
Peak torque (SAE Gross J1349) 11 kg-m (80 ft-lb)/2,200 rpm
Minimum fuel consumption 225g/Hp-hr (0.496 lb/HP-hr)/3,200 rpm
Fuel and type Gasoline, 4-cycle, O.H.V.
Cylinder arrangement 4 in-line
Combustion chamber Wedge shape
Bore x stroke 76mm x 82mm (2.99 x 3.23 in)
Total piston displacement 1,487 cc (90.74 cu in)
Compression ratio 9.0 : 1
Length x width x height (standard model)
  527.8 x 530.8 x 576.3mm (20.78 x 20.90 x 22.69 in)
Dry weight (standard model)* 103kg (227 lb)
