The 60-series transmissions can handle the torque from A14 and A15 engines. So the 60 four-speed is stronger than the 56 four-speed which was used behind A12 engine. The 60-series 5-speed is a beefier model than the stock Datsun 1200 GX-5's 56-Series Transmission. These 5-speeds came in the 1977-1982 Datsun B310 (210/Sunny/140Y/150Y). The four-speeds came behind A14s & A15s.
| Gearbox Swaps | |
| Types: 56 | 60 | 63 | 71 | 90 | R30 | |
| Transmission Swaps | |
| Identification | |
| 5-Speeds | F5C56A | Stumpy | |
| 6-speed | |
| Toyota 5-speed | |
| Manual/Auto conversion | |
| more: Transmission Modifications |
Look for the '60' casting mark on the right side of the gearbox:
Also see 60 5-speed v 4-speed for more identification tips.
60-series transmissions were used exclusively behind A14 and A15 engines, due to their ability to handle more torque than the smaller 56-series. However, starting with the B310 it was also offered behind the A12.
* B310 GL with A12 (B310H) came with optional 5-speed 60L (B310HF) * FS5W60L used through 8010 (end of A12 in Japan) * A13 (debut 8011) used 60A
60-series transmissions came in three varieties: * 60L four-speed for A-series engine * 60L five-speed for A-series engine * 60A five-speed for A-series engine
60L for A-series engine * Four-speed: 1975 to 1982 * Five-speed: 1977-1979 B310 Sunny (manufactured through 1979 September) * Dogleg shift pattern
60A five-speed for A-series engine * 1980-up B310 Sunny (from 1979 October) * Standard shift pattern
Note that 60-series gearboxes may be available for other engine types, so make sure you get one to match the A-series engine.
Gear Ratios
(see 5-speed Gear Ratios)
box 4th 3rd 2nd 1st 5th Rev 60L 4-speed 1.000 1.378 2.170 3.513 3.764 60L 5-speed 1.000 1.378 2.170 3.513 0.846 3.464 60A 5-speed A 1.000 1.378 2.170 3.513 0.821 3.764 60A 5-speed B 1.000 1.320 2.170 3.513 0.821 3.764
NOTES
- The 1st through 4th gears are all the same -- 4-speed and 5-speed -- except for a few 5-speeds with 3rd closer to top (larger gap from 2nd to 3rd).
- For freeway driving, the 60A has a larger overdrive and so is preferable to the 60L dogleg.
- First gear is the same in all 60-series boxes
Swap Notes
When swapping a 60 transmission into a 1200, these parts should be obtained from the donor car:
* Transmission * Release Lever which differs from the 1200 part * Release Bearing sleeve, which may differ from the 1200 version * Shifter * #Rear Crossmember or at least the rubber insulator
* the 60a 4-speed and 60a 5-speeds are the same length as the stock Datsun 1200 transmission, and the shifter is in the same spot
Rear Crossmember
The rear engine crossmember, that is to say the Gearbox Crossmember.
B310 stock 60-series rear engine crossmembers
60L has a 20mm dip in it. 60A is level.
Pitroad says the South Africa Datsun Bakkie (B140) had a FS5W60A 5-speed, and that the trans crossmember might work for a B110. B140 Gearbox crossmember for FS5W60B is pictured below. It appears the tunnel mounts are fitted further back than in the 1200.
The 56-series mount (insulator) fits inside the crossmember, and bolts to the sides of the crossmember:
1200 style mount
- 11321-H1000 ASSY-INSULATOR ENGINE MOUNTING REAR B110 MANUAL
- 11321-H1020 ASSY-INSULATOR ENGINE MOUNTING REAR B110 AUTOMATIC
- 11321-H6200 ASSY-INSULATOR ENGINE MOUNTING REAR B210 A13 MANUAL TO 0873 [56-series]
- 11321-H6201 B210 A14 0978-0874 [60-series 4-speed]
- 11321-H7300 B210 A14 0974- [60-series 4-speed]
- 11323-H7310 [63-series 5-speed]
- 11321-H6201 INSULATOR ASSY-ENGINE MOUNTING REAR B310 A12A MANUAL [56-series]
The 60-series insulators sit on top of the crossmember, and bolts from the bottom:
B310 60-series rear engine mount
- Uses two M8 X 1.25 NUT
- 11320-H9100 INSULATOR ASSY-ENGINE MOUNTING REAR B310 A14/A15 MANUAL [60-series]
- 11320-W5800 INSULATOR ASSY-ENGINE MOUNTING REAR B310 AUTOMATIC
Using 1200 Crossmember
The stock 1200 crossmember can be adapted to fit a 60-series transmission. It depends on which 60 (60L vs 60A).
60A crossmember bosses are level with 1200 brackets, so spacers can be fitted
60L bosses are 20mm above the 1200 brackets, so no spacers are needed
post
The main problem is that the 60-series bosses are further back than the 56-series:
To compensate for this:
- The tunnel brackets can be moved back
- OR, an adapter plate can be use on the rubber insulator
Automatic-tunnel 1200
Automatic 1200s will fit the 60 by reversing the stock 1200 crossmember.
Manual-tunnel 1200
Stock 1200 mount fitment (56-series)
60-series fitment with stock unmodified 1200 crossmember -- using simple adapter plate between rubber mount and gearbox:
The wide holes bolt to the 60 transmission mount boss
The narrow holes bolt to the top of the 56 rubber mount
C dimension is the offset
Similar treatment done with non-Nissan gearbox:
Simple rectanguler plate with four holes drilled
60L fitment with stock 1200 crossmember. The rubber mount is modified (plate welded to the rubber mount top plate, and the original holes trimmed off for factory appearance):
click
click
click
Chris's Rip Snorter A12 & Red B10 -- classic cut & shut. Slice up the old mount & crossmber then reweld it.
60-series fitment with modified 60-series crossmember:
- crossmember narrowed, cut to fit into 1200 tunnel
- tabs welded to the crossmember
Using B310 Mount
Or, use the B310 60-series rubber insulator with a simple custom crossmember that bolts to the original crossmember points.
60-series rubber mount* See Gearbox Crossmember#Rubber_Insulator for part numbers
NOTE: There is a difference in how a 60L 5-speed and a 60A 5-speed mounts. Apparently the 60L is lower by 20mm. When using a 60A custom crossmember, 20 mm spacers may be required to fit a 60L.
Flat Steel Crossmember
Fabricate a u-shaped flat steel adapter, then bolt on for a 60L (4 or 5 speed). For the 60A, fit it with long bolts and spacers.
60 custom crossmember for Datsun 1200
A sleeker version can also be fabricated:
* The rubber insulator picture is a stock 60-series rubber unit.
Bprojects 60A Install Kit
Bprojects sells a sophisticated kit which doesn't need long bolts or spacers. Buy at B-Pro, which replaces both the rubber mount and the crossmember:
click
Fits 60-series to Datsun 1200 manual tunnel.
Pitroad 60A Fitting Kit
Pitroad sells a kit to place a 60A into a 1200:
They say it will also work for 60L if 20mm spacers are used.
Home-built Kits
OR, cut down a 60-series crossmember and weld angle-iron to it:
holes offset ~40mm and ~230mm apart
Custom Crossmember
Various type can be used, including:
* Wide crossmember, bolted to floor pans * Modified stock crossmember * Solid-mount
Wide Crossmember
A wide crossmember can be bolted to the floor pan using large washer for reinforcement. Then the original 1200 gearbox body brackets can be removed, providing enough space for the reverse lamp switch.
universal gearbox crossmember designs
A piece of 40mm box steel will do the job. Bolt it to the rubber mount of the gearbox and then bolt it to the floor - add some spacers as required.
PIGDOG welded late model Nissan floor boss
Modified Crossmember
A 1200 crossmember was welded to a B210 crossmember
Solid Mount
If you don't mind vibrations, the rubber isolator can be left out. This makes the 60A 5-speed easy to bolt up. The 60L can be treated similarly but needs spacers.
The 60A is flush to the existing 1200 mounting ears
full
So a flat bar can be used (the stock B310 crossmember dips down to provide room for the rubber mount)
full
The new crossmember (flat bar) just needs offset bolts, making it into a sort of u-shaped flat bar
full
Tailshaft
The stock Datsun 1200 driveshaft should be used. While the B310 driveshaft is the same length, it has the larger H150-style rear flange.
Reverse Switch
The location of the Reverse Switch can differ between all the different transmission. It is a problem when fitting any 60-series gearbox in to the small 1200 manual tunnel. The reverse-light switch is right where the Datsun 1200 chassis x-member mount is.
Options to work around this problem include:
Plug
Remove the Reverse Switch, discard it, then plug the hole. A spare A12 engine-block drain plug fits (from the side of the engine block). Optionally you can fit a switch to the shifter to activate the reverse lamp.
* Fit a shifter-mounted Reverse Switch * Fit a switch plug in the transmission![]()
If you screw the plug in too far you end up effectively stopping the shift from traveling over far enough to make either the shift up to 5 or down to reverse. There must be a millimeter or so play.
Clearance Tunnel
Cut a hole in the side of the tunnel bracket and let the switch protrude into it.
Tunnel Swap
Fit a tunnel removed from an automatic-transmission 1200, a B140, or a larger Tunnel such as B210 or 610 which helpfully is the exact shape needed for a 1200.
Crossmember Modification
Remove the 1200 original crossmember tunnel brackets and fit a wide crossmember. See Custom Crossmember
OR fit a custom low-profile crossmember. This is what is used with V8 in Datsun, so it should be plenty strong
OR for a more factory look ...
Remove the 1200 original crossmember bosses and move them back
The brackets are tack-welded, so you can drill out the welds, and remove the brackets in one piece.
Use a simple flat plate (8mm thick) for the crossmember and use the 60-series rubber insulator mount.
Use the stock 1200 crossmember and insulator. Idea - will this work? Cut the corners off the stock 1200 rubber mount, drill new holes farther apart so it fits the larger gearbox:
B140 Gearbox crossmember for 4-speed 60L or for 5-speed (60A/60B). These may bolt right in after the 1200 tunnel brackets are moved back?
Uses the stock B140/B210/B310 (A14/A15) rubber insulator
Swap Into Datsun 1200
(A special note of thanks to Davo1200 who started this article originally in the old Tech Section)
How do I install a 5 speed Sunny box?
Vanette Transmission
FS5W60A vs RS5W60A 5-speed comparo
RS5W60A -> FS5W60A CONVERSION KIT
Parts
See main article: 60-Series Transmission Parts
