Automatic Shifter
Revision as of 01:55, 13 August 2015; view current revision
Category: Automatic Transmission
Datsun 1200 with Automatic Transmission was fitted a floor shifter and a console.
Console
See main article: Console
DX console:
GL console:
th_B110%20auto%20bezel%20c.jpg th_B110%20auto%20bezel%20b.jpg th_B110%20auto%20bezel%20d.jpg
Shift Control
The shift lever unit bolts to the floor. The lever extension is on the right side, and via a Cross Rod, goes under the extreme rear of the transmission, then connects to the Shift Rod which is on the left side of the car.
Automatic Transmission Control
This photo shows the Shift Rod lever on the right side of the transmission. Note the Cross Shaft Bracket (bracket with a hole) bolted to the rear of the transmission.
B110
* 34952-H1100 COMP.-BRACKET, cross shaft
B210 is slightly different in that the gearbox rubber insulator incorporates one of the Brackets for the Cross Rod
* 11343-H5020 SUPPORT ASS'Y-cross shaft [left side hole]
* Insulator, Mounting [has right-side hole]
, B210 shift mechanism is simplified in several ways. It may interchange if all the parts are used (bracket + Mount + shifter + shift Rod).
Interior Shift Unit
Shift Knob
* 34919-H1100 LEVER-hand B110
* 34920-P4926 KNOB-CONTROL LEVER B210
Bushings
34907-25820 BUSH-HAND LEVER BRACKET
B210: 34430-73001 BUSH-CROSS TUBE (2)
34462-18000 BUSH-SPHERICAL CROSS SHAFT
B210: 34552-89900 INSULATOR
Shift Linkage
Bushings
34462-18000 BUSH-SPHERICAL CROSS SHAFT (2) B110,B210
34552-89900 INSULATOR-ROD (4) B110,B210 [34410A, 34413B]
