38100 SET-HYPOID GEAR & PINION
By popular usage "diff" is also used to refer to these parts:
- the Gear Carrier Assembly (pumpkin or "center section" or "diff head"), including Ring and Pinion and the carrier these bolt to
- or, the entire Rear Axle assembly including the housing, gears, axles etc.
Gear Carrier aka "center" (not to be confused with "center section")
38100 SET-HYPOID GEAR & PINION |
Spider gears: The smaller side gears are known as the "spider gears". These are the ones that actually allow a differential speed.
38423 GEAR-SIDE 38427 SHAFT-PINION 38425 GEAR-PINION |
LSD: Limited-slip differential. Most designs use a spring-loaded clutch to prevent one wheel from spinning by itself. Instead, the LSD resists spinning but when traction is overcome, both wheels will spin.
