Engine
Revision as of 02:26, 30 March 2008; view current revision
Category: Engine Mechanical
The Datsun A12 engine is the most common A series engine to be found. They are commonly found in most countries and came out in the B110 and B210, known as the Datsun 1200 and 120y.
All A series engine blocks, from the 7/73, were modified with a better method of providing oil to the camshaft, the distributer moved back and the altenator swapped from right to left.
770.jpg A12 Engine ID Mark
Specifications:
  • Bore: 73mm
  • Stroke: 70mm
  • Connecting rod: 121.5mm
  • Block Hieght: 189.1mm
  • Displacement: 1172cc
  • Power: 68hp or 69hp (depending on year and country)
