For use with Electric Fuel Pump. Instead of leaving the stock mechanical Fuel Pump in place, it may be removed and the blanking-plate fitted. Also known as a delete plate, cover plate, block off plate or <fuel+plate>.
Nissan
Nissan fitted a blank-off plate to the A14/A15 fuel injected engines in Japan. The same plate was used in most countries for other Nissans.
Buy from Bprojects (info about Bprojects) or find online 16420-E0100ᴳ
Nissan 16420-E0100 SPACER-FUEL PUMP $16.10 USD * 00915-13610 WASHER (2) * 08120-61210 BOLT M6x12 (2) * <17099-21002> GASKET-FUEL PUMP * Fits A-series, L-series, E-series, Z-series engines
Right side of engine (from Introduction of Sunny GX-E)
Wrecking Yard
If sourcing from a wrecking yard, look for these EFI vehicles:
- 1979-1982 Nissan B310 SGX-E/GX-E (Japan market)
- 1979-1983 Nissan S110 200SX with Z20E/Z22E
- 1980-1986 Nissan 720 Pickup with Z22
- 1987-1989 Nissan N12 Pulsar NX XE with E16
- 1987-1989 Nissan B12 Sentra with E16I
Datskool110
Show plates by POST Datskool110
Bluehands
info at Ratsun fuel pump block off plate
CAD file
