Template:Diff Terminology
Revision as of 22:59, 30 January 2017; view current revision
Differential: The word "diff" refers to the small gears in the rear end that control the left-to-right wheel speeds
38100 SET-HYPOID GEAR & PINION
open type with differential gears visible
Datsun 1200 uses H145 type differential
By popular usage "diff" is also used to refer to these parts:
  • the Gear Carrier Assembly (pumpkin or "center section" or "diff head"), including Ring and Pinion and the carrier these bolt to
  • or, the entire Rear Axle Assembly including the housing, gears, axles etc.
Axle Housing
Axle aka axle shaft (includes wheel bearing)
Gear Carrier aka "center" (not to be confused with "center section")
Ring and Pinion (R&P) are the large final-drive gears e.g. the "ratio" gears. Known as "Crown Wheel and Pinion" (CWP) in British English.
Spider gears: The smaller side gears are known as the "spider gears". These are the ones that actually allow a differential speed.
38423 SIDE GEARS
38427 PINION SHAFT
38425 PINION GEARS
LSD: Limited-slip differential. Most designs use a spring-loaded clutch to prevent one wheel from spinning by itself. Instead, the LSD resists spinning but when traction is overcome, both wheels will spin.
