1400 Bakkie
Revision as of 03:41, 23 November 2025; view current revision
Categories: Documentation | Sunny Truck
<-- back to South Africa Brochures
Title: 1400 Bakkie [white Nissan 1400]
1986.02 South Africa bakkie B140
Format:single-sheet, two sides Size:295 x 210mm Publication Number:AD 002 B140 SDX
1400 Bakkie Standard/Standaard & Deluxe
31320.jpgAlbum 31320
1400 BAKKIE
NISSAN
We are driven
Ons het dryfkrag
Specifications/Spesifikasies
We are driven NISSAN Ons het dryfkrag
31321.jpgAlbum 31321
ENGINE/ENJIN
Type/Tipe         4 Cylinder OHV/4 Silinder Kopklep
Displacement/Verplasing (cm)            1397
Compression ratio/Kompressieverhouding  9.4
Bore & stroke (mm)/Boring en slag (mm)  76 x 77
Max. Power Kw @ rpm (SABS)/             47 @ 6000
Maks. Krag Kw @ r/min (SABS)
Max. Torque Nm @ rpm (SABS)/            97 @ 2500
Maks. Wringvermoe Nm @ r/min (SABS)
Fuel supply/Brandstottoevoer
     Hitachi dual barrel downdraught carburettor/
     Hitachi dubbelkeel-valstroom-vergasser
Fuel tank capacity (l)/                 37
Brandstofinhoudsmaat (l)
SUSPENSION/VERING
Front/Voor
Independent strut type with coil springs & stabiliser bar/
Onathanklik stuttipe met kronkelvere en stabiliseerstaaf
Rear/Agter
Live axle, Semi-elliptic leaf springs/
Draaias, Halfelliptiese bladvere
Shock absorbers/Skokbrekers
Telescopic double-acting/Teleskopiese dubbelwerkende
WHEELS/WIELE
STANDARD/STANDAARD   4Jx12 pressed steel/Persstaal
DELUXE               5.5Jx12 alloy/allooi
spare/noodwiel       4J x 12 pressed steel/persstaal
TYRES: Type & Size/BANDE: Tipe & Grootte
Radial Ply/Straallaag 155SRx12
STEERING: Type/STUUR: Tipe
Recirculating ball/hersirkuleerkoeël
TURNING CIRCLE/DRAAISIRKEL (m)           8.2
BRAKES: Type/REMME: Tipe
Power assisted, dual line with front discs and rear drums/
Kraghulp-dubbelleiding met skywe voor en trommels agter
ELECTRICAL SYSTEM/ELEKTRIESE STELSEL
Battery-Type & Capacity/Battery-tipe & Vermoë
12V-45AH negative earth/negatiewe aarde          45A
COOLING SYSTEM/KOELSTELSEL Capacity (l)/Kapasiteit (l)
Pressurised radiator with centrifugal pump/
Drukverkoeler met sentrifugale pomp              4.7
TRANSMISSION/TRANSMISSIE Type/Tipe
4-speed manual/spoed handrat
Ratios/Verhoudings 1st/1ste             3,757
                   2nd/2de              2,169
                   3rd/3de              1,404
                   4th/4de              1,000
Final Drive/Eindaandrywing              3,89
Reverse/Trurat                          3,640
Drive Wheels/Aandrywingswiele      Rear/Agter
DIMENSIONS/AFMETINGS mm
Overall Length/Totale Lengte            3845
Overall Width/Totale Breedte            1495
Overall Height/Algehele Hoogte          1425
Wheelbase/Totale Asafstand              2300
Ground clearanc/Grondvryhoogte           160
BOXDIMENSIONS/KASAFMETINGS(mm)
(Floor) Length/(Vloer) Lengte           1518
(Floor) Width/(Vloer) Breedte           1285
Height/Hoogte                            415
MASSES/MASSA's:              Standard Deluxe
Tare Mass/Tarramassa Kg              758     774
G.V.M. Kg/B.V.M. Kg                 1394    1394
Gross Payload Kg/Brutoloonvrag Kg    591     575
STANDARD FEATURES:
INTERIOR: Heater/Demister. Glove box with latch. Warning lightsfor: handbrake, oil pressure, no charge, hazard warning. Bench seats with perforated vinyl inserts (std only). Inertial seat belts. Interior courtesy light. Floor mounted handbrake. High quality moulded floor carpets in cab. Locking steering column. Curved rear window.
EXTERIOR: Front black bumper. Opening door vent windows. Dual exterior mirrors. Rear window protection bars. Styled pressed wheels. Half wheel cover.
ADDITIONAL FEATURES FOR DELUXE MODELS: Door armrests. Cigarette lighter. Clock. Cloth door insert panel. Individual seats. Cloth facing. Day/night rearview mirror. Trip meter. Body protection side mouldings. Alloy wheels. Tonneau cover. Semi matt-black radiator grille. Chrome exhaust extension. Instrument panel dimmer switch.
STANDAARDKENMERKE:
BINNEKANT: Verwarmer/ontwasemer. Sluitbare paneelkissie. Klikliggies vir: handrem, oliedruk, battery laai nie, noodwaarskuwing. Banksitplek met geperforeerde vinielinsetsels (net std). Oprol- sitplekgordels. Hoflikheidsliggie. Handrem op vloer. Hoë-gehalte gevormde tapyt in kajuit. Sluitbare stuurkolom.
BUITEKANT: Swart buffer voor. Deursyvenstertjie wat oopmaak. Twee buite-truspieëls. Beskermstawe vir agterruit. Gestileerde persstaal-wiele. Halwe wielbedekking. Geboë agterruit.
BYKOMENDE KENMERKE VIR DELUXE-MODELLE: Armleunings aan deure. Sigaretaansteker. Horlosie. Materiaalinsetsels in deurpanele. Afsonderlike sitplekke. Materiaalbelegsel. Dag/Nag-truspieël. Ritmeter. Gevormde bakskermstroke. Allooiwele. Bakseil. Semi- dofswart verkoelerrooster. Verchroomde uitlaatverlengstuk. Instrument-verdowingsliggie.
Part No/Onderdeelnr: AD 002 B140 SDX
(Effective date/Effektiewe datum: February/Februarie 1986
All illustrations and specifications in this brochure are based on the latest information available at time of publication. Nissan S.A. (Pty) Ltd. reserves the right to make changes at any time, without notice, in prices, colours, materials, equipment, specifications, and models, and to discontinue models or equipment. For information on options and accessories, please contact your local Nissan dealer.
Alle illustrasies en spesifikasies in dié brosjure is gebaseer op die jongste inligting beskikbaar ten tye van publikasie. Nissan S.A. (Edms) Bpk. behou die reg voor om sonder kennisgewing ter enige tyd veranderings aan te bring in pryse, kleure, materiale, toerusting, spesifikasies en modelle en om modelle of toerusting te staak. Skakel asseblief u Nissan-handelaar vir inligting oor opsies en bykomstighede.
BM LITHO                                       14692
