L4N71B Swap
Revision as of 01:26, 20 April 2009; view current revision
Category: Automatic Transmission
A 4-speed JATCO L4N71 was made during the 1980s. The top gear is an overdrive ratio, for reduced revs at highway speeds. It also has a lockup system (3rd and fourth gears are direct) for fuel-economy approaching that of a manual transmission.
Will it fit into an automatic-bodied Datsun 1200? Unknown -- try it and let us know.
Sources
JATCO 4N71B series:
  • LN471B: Light duty
  • EN471B: Medium duty
The 4N71B 4-speed automatic came in Maximas and 200SX (silvia) models, as well as in Datsun pickups and Mazdas.
Australia Models
  • VL Commodore
US Models
  • Nissan Maxima 1983 (L-series bell housing)
  • Nissan Pathfinder 1986-1989
  • Nissan Van 1987-1989 (the 'rare as' USA Vanette)
  • Mazda 929 1988-1990
  • Mazda B2000\B2600 1987-1991
    • 1987-1988 has Mitsubishi bell housing?
  • Mazda Miata 1991-1997 (Mazda N4A-EL)
  • Mazda RX7 1984-1988
Also:
  • 1984–1988 Nissan 200SX
  • 1984–1989 Dodge/Plymouth Conquest
  • 1984– Mitsubishi Starion
  • 1986–1989 Nissan pickup
  • 1989–1995 Mazda MPV
E4N71B
  • 1984–1989 Nissan 300ZX
  • 1984–1989 Dodge Conquest
  • 1987–1988 Nissan 200SX
Has two drawing of 4N71B vs 3N71B: http://forums.hybridz.org/showthread.php?t=130117
Looks like six inches of length added in the middle.
Comparo of 3-speed to 4-speed
  • 4-speed is bigger around at the back, probably requires tunnel mods
  • New rear engine crossmember (gearbox crossmember) will need to be fabricated
  • Wiring changes are needed
  • Swap converter housing with an A-series one
  • Stall speeds vary, so swapping converters may be needed to find one that suits the small engine
Approximate Junkyard Costs:
  • L4N71B 4-speed OD transmission from Pick-N-Pull: $130
  • Flex plate including crank shaft spacers: $20
  • Auto shift lever from early Datsun: $18
  • Kickdown switch and mounting bracket from early Datsun: $3.50
  • Automatic-size Brake pedal: $3
  • Maintainence items (filter, seals, modulator): $32
  • Hard fluid lines from B310: $9
  • Flexible Fluid hoses: $10
  • Radiator with auto-trans coolor lines: ?
  • Driveshaft shortened, rebuilt, balanced: $165
    • length is 2.7 cm (about one inch) longer
  • New rear transmission mount: $25
  • Hardware (bolts, nuts, metal spacers): $15
  • L3N71A/L3N71B converter housing for A-series engine
    • Will this fit on the L4N71B?
references:
More generally:
  • 84-89 Chrysler, Dodge Plymouth
  • 83-89 Mitsubishi
  • 84-89 Nissan Cars
  • 86-89 Nissan Pick-ups, Vans
  • 84-93 Mazda Cars
  • 88-95 Mazda Trucks
